Cel On! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-20-2007, 08:01 PM   #1 (permalink)
View 99lecamry's Photo Gallery
4th Generation Cel On!
So I Installed A Sri According To One Of The Diy's On The Diy List A Few Weeks Ago I Know I Read Sumthin About Pple Get Cel's Every Once In A While With The Sri. I Have A Gen4 4cyl. I Didnt Get The Code Read Yet Im Gonna Go To Autozone Tomoro But In The Mean Time Any One Have Any Ideas Wut Could Be Causing This?
99lecamry is offline   Reply With Quote
Old 08-20-2007, 09:31 PM   #2 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
try resetting your batt. unplug it.
there is a change in the air/gas ratio. Your car's computer noticed that and most likely the CEL came on.
skewe is offline   Reply With Quote
Old 08-21-2007, 01:48 AM   #3 (permalink)
I work on euros.
View 96CamrySport's Photo Gallery
I doubt it would have caused a 10% change in LTFT...that is the minimum for setting a p017x code. my bet is it's something else, post up the code when you get it...
1996 Camry Sport (that's a DX Coupe with decals) with 186k
european cars are just like japanese cars, just heavier and more expensive.
7 ASE's.
96CamrySport is offline   Reply With Quote
Old 08-21-2007, 06:31 PM   #4 (permalink)
4th Generation
they tell a po420 code at autozone it was a dumbass kid who didnt know wut he was doin so he didnt tell me causes he just told me the code so im relying on you guys thanks in advance
Old 08-21-2007, 08:57 PM   #5 (permalink)
4th Generation
any body know what the cause of this code mean i would appriciate some input thanks
Old 08-21-2007, 09:07 PM   #6 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
PO420 is a catalytic converter efficiency code. The ECU monitors the front and rear oxygen sensors for a difference in waveform to determine if the catalytic converter is operating normally. When the rear sensors output looks similar to the front, it is an indication that the catalyst is failing, and PO420 is set. Generally when this code is set alone it is indeed indicative of a failed catalytic converter, but should still be diagnosed to rule out any other possibility given the cost of the part. The test is pretty simple, and any technician with a scan tool that can monitor O2 sensor waveforms can get it done.
Qslim is offline   Reply With Quote
Trouble with the CEL nodrogkam Camry & Solara Lounge 4 05-24-2006 10:45 PM
'91 CEL (check engine light) kamesama980 Archived Corolla threads 5 04-20-2006 11:21 PM
CEL Mystery Mousiee Camry & Solara Lounge 0 10-05-2005 06:07 PM
cel 05 xrs mmartin1872 Archived Corolla threads 0 07-24-2005 09:34 PM
2004 CEL - VVTI problem bluemm Archived Corolla threads 2 10-18-2004 09:32 PM
