need some troubleshooting help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-21-2007, 12:39 AM   #1 (permalink)
View bp25's Photo Gallery
3rd Generation need some troubleshooting help
I have a 1996 Toyota CAmry 4cyl. And the engine light came on, I did a check and the code reads as .....
p0441
Does anyone know what it stands for and where the problem is located? Any information would be very helpful....?
bp25 is offline   Reply With Quote
Old 08-21-2007, 01:02 AM   #2 (permalink)
View mikeyq926's Photo Gallery
P0441 EVAP Emission Control System Purge Flow Fault
hmmm... not sure where the problem would be... im guessing it has somethin to do wit evap, canister, purge valve or solenoid.
1995 Camry LE 2Door
126,700 and counting...
Pwn IT!
mikeyq926 is offline   Reply With Quote
Old 08-21-2007, 10:03 PM   #3 (permalink)
Ok So I found out wht the code reads...now does anyone here know where it is located?
It has something to do with the evap charcoal canister..? any pics or anything would be helpful...thanks
Old 08-23-2007, 01:09 AM   #4 (permalink)
I work on euros.
View 96CamrySport's Photo Gallery
a purge flow fault means that either it flows when it shouldn't or doesn't flow when it should. it's calculated by reading the fuel trims while purging. If the fuel trims don't change within a certain range, it throws.
1996 Camry Sport (that's a DX Coupe with decals) with 186k
european cars are just like japanese cars, just heavier and more expensive.
7 ASE's.
96CamrySport is offline   Reply With Quote
ECM vs Auto Trans troubleshooting 05 LE klxdrt Archived Corolla threads 0 06-23-2007 02:24 PM
2 New/Revised TSB's - Audio Troubleshooting, Special Service Tools njerald 5th & 6th Generation (2002-2006 & 2007-2011) 0 03-02-2007 03:34 PM
Diagnostic or Troubleshooting Tree wreckerboy Archived Corolla threads 2 12-19-2006 02:02 PM
Troubleshooting '94 Pickup Cruise Control? 4x4pickup 89-95 Toyota Pickup/Hilux 0 08-16-2005 08:59 PM
1990 tercel troubleshooting tips, my story... bulldog Tercel, Paseo, Starlet, and Sera Forum 4 07-24-2004 10:52 AM
