Steering WHeel Isn't Straight... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-21-2007, 12:47 AM   #1 (permalink)
It's pronounced "Nesquik"
View N35QU!K's Photo Gallery
3rd Generation Steering WHeel Isn't Straight...
For some reason, on my '92 Gen3, to go straight, I have to turn the wheel ever so slightly to the right... Its pretty noticeable when you're driving.
What's the problem, and how can I fix it?
Click image for vehicle info (UPDATED 12.01.09)
N35QU!K is offline   Reply With Quote
Old 08-21-2007, 12:57 AM   #2 (permalink)
View mikeyq926's Photo Gallery
most likely wheel alignment. tho most front wheel drive cars have a tendency to ever so slightly either steer left or right because of wheel torque. my car veers to the right very slightly because of it too.
1995 Camry LE 2Door
126,700 and counting...
Pwn IT!
mikeyq926 is offline   Reply With Quote
Old 08-21-2007, 12:59 AM   #3 (permalink)
View vdop69's Photo Gallery
I experience the same thing on my 00 Camry, Ive had it aligned and when driving straight the wheel is slightly slanted to the right. Maybe its normal?
vdop69 is offline   Reply With Quote
Old 08-21-2007, 01:54 AM   #4 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
As mentioned, this can be corrected with an alignment. Was probably caused by one. The wheel has to be held perfectly straight as they make their adjustments.
Dave's is offline   Reply With Quote
Old 08-21-2007, 10:31 PM   #5 (permalink)
View Novice_cardude's Photo Gallery
Most likely an alignment issue, but it can be several things:
1. A bad front-end part is allowing toe to shift in or out on one side, bringing the steer ahead over to the left, so to go straight, you gotta put the wheel to the right.
2. Toe simply shifted due to scuffing a curb (it doesn't take much at all), or normal wear and tear on front end parts and bushings.
3. Rear thrust angle has changed, again due to bumping a curb (I did it once barely moving at all backing into a parking space, and my wheel shifted a little to the left), making you dog walk slightly, thus you gotta turn your wheel to the right to compensate for the dog walk.
Could be some other things too. Most places have a free alignment check, so you can at least see where you're sitting. If that's the cause of the problem, go from there.
Novice_cardude is offline   Reply With Quote
Old 08-21-2007, 10:39 PM   #6 (permalink)
The Greek....
GrkBallaG's Avatar
iTrader Score: 13 reviews
View GrkBallaG's Photo Gallery
Maybe its normal to have techs up there who cant do an alignment worth shit . Everytime i do an alighment i dont let it go out the door with out the steering wheel being perfectly str8, its a good habit i have
The SLAMry.....
Slammed, Carboned, 5sp Swapped, Big Braked, RMM Lipped And Ready To Be Daily Driven!
Originally Posted by UfoZ View Post
Tits! Best non turbo Camry there is.
GrkBallaG is offline   Reply With Quote
Old 08-22-2007, 09:52 AM   #7 (permalink)
The Camburger
iTrader Score: 6 reviews
View Admiral's Photo Gallery
i too discovered i have the same issue this week. I thought it was an alignment issue and apparently isn ot. The guy at the shop said it has what is known as 'torque steer'. I dont know if that is correct or not. You will know 'torque steer' is the problem if when you take your foot off the gas, it goes in a straight line, but when you apply the accelerator it starts veering to one side. I notice on mine that the harder I hit the gas, the more it drives crooked. It was suggested to me by someone... (someone that blows things out of proportion)... that it could be tie rods/ control arms/ bushings/ etc.
But get the alignment done first and see how things go.
Admiral is offline   Reply With Quote
Old 08-22-2007, 02:08 PM   #8 (permalink)
yes it is torque steer because front wheel drive cars are well... front wheel drive. haha
1995 Camry LE 2Door
Pwn IT!
Old 08-22-2007, 02:40 PM   #9 (permalink)
That sounds about right... And it has something to do with the LSD, right?
Old 08-22-2007, 05:18 PM   #10 (permalink)
bitch please
DarkMastyr's Avatar
View DarkMastyr's Photo Gallery
Torque steer is because the half shaft on front wheel drive cars are different lengths left and right. When you mash on the gas hard enough, one of the half shafts spins momentarily faster than the other, and you get spin in one wheel. An LSD attempts to minimize this effect.
1994 Camry 2.2L LE Auto
DarkMastyr is offline   Reply With Quote
Old 08-22-2007, 05:28 PM   #11 (permalink)
The Greek....
GrkBallaG's Avatar
That is correct.
The other part not so much so. Torque steer is not caused by one of the shafts spinning faster than the other, its caused because one shaft is longer than the other and torque transfers better through the longer one than the shorter one, thus causing the vehicle to pull to the left or right. Nissan maximas (v6) are infamous for torque steer.
The SLAMry.....
Old 08-22-2007, 05:54 PM   #12 (permalink)
View Fredrick2003's Photo Gallery
So is there any way to prevent torque steer?
Fredrick2003 is offline   Reply With Quote
Old 08-22-2007, 06:20 PM   #13 (permalink)
Experience>Post Count
View MIC0417's Photo Gallery
get a rwd car
MIC0417 is offline   Reply With Quote
Old 08-22-2007, 06:28 PM   #14 (permalink)
The Greek....
GrkBallaG's Avatar
Equal length shafts and thats about it
The SLAMry.....
Old 08-22-2007, 08:22 PM   #15 (permalink)
But you can't really do that, because of the way the Camry was designed, right?
2006 Scion XA Steering Wheel Question ScionXA2006 xA Forum 5 08-10-2006 01:22 PM
HELP: The steering wheel seem not alined. NewRacer Camry & Solara Lounge 7 05-27-2006 04:29 PM
Recovering my steering wheel... RodMillenFan Camry & Solara Lounge 2 05-23-2006 07:09 AM
How-To: 89+ Non-Airbag Steering Wheel into Pre-89 (MKIII) Jeff Lange Supra Forum 1 10-13-2005 01:17 AM
how to install new steering wheel? cman2000 Camry & Solara Lounge 10 02-26-2004 10:46 AM
