Automatic Transaxle leak
I have a 1995 Toyota Camry 4 cyl. Automatic. The rear cover / plate on the transaxle differential housing appears to be leaking at the top. I cleaned everything good to locate the leak. First I changed the speedometer o-ring thinking that was the problem. The area again got wet with red fluid. The area around the base of the vent is dry. The fluid appears to be coming from the mating surface of the rear cover to the transaxle differential housing. I’m nervous about removing the cover plate, as I’m unsure what is behind it. I don’t want bearings, springs, and shafts etc falling out. Could someone please advise me as to what to expect if I remove the cover and replace the gasket /seal. I am aware that I will need to drain the fluid from the transaxle differential housing before removing the cover. Thanks for any help.
