What parts? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-21-2007, 02:44 PM   #1 (permalink)
hav
View hav's Photo Gallery
4th Generation What parts?
While doing the Timing belt change what else do you guys think would be worth changing apart from the water pump. I want to go to the store and get all the parts together.
My list is:
1. Timing Belt.
2. Water Pump
3. Water Pump Gasket.
Do you guys think I should also change the tensioner. the car has 120 K. It's a 99 V6
Thanks
hav is offline   Reply With Quote
Old 08-21-2007, 02:50 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
yes, if ur already gonna have someone or urself down there then change it all
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 08-21-2007, 02:55 PM   #3 (permalink)
hav
Do I have to get the Toyota dealer belt or after market belts are fine?
Old 08-21-2007, 03:37 PM   #4 (permalink)
View hoiskii's Photo Gallery
I have changed the tensioner and idler pulley also. They cost me $80 extra, BUT
when I've looked at the tensioner closer I've found its bearings are getting loose already, so it was I'd say right time to change it.
I installed Dayco belt/pulleys, so far so good... for 1 day.
BTW, the broken water pump and tensioner were original Toyota parts, nothing lasts forever.
NGK may produce good belts/pulley also.
Also, you may consider changing PS belt and Alt/AC belt, but you can do them anytime later, I think it takes 5 min or so to change them.
Or, almost forgot, you may need a timing belt cover gasket!!!! I've found I need it in the middle of my timing belt work and it was not available in stores at the time, so I have used some black high temperature "liquid polymer" (??) gasket from Autozone instead.
And make sure you rent right puller for your pulley (the pulleys can be different, so look at the pulley first before going to the store).
hoiskii is offline   Reply With Quote
Old 08-21-2007, 07:34 PM   #5 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
I think it does not matter if u got a part from toyo or autozone.
I changed my tensioner, idler, 2 belts and water pump.
for my 2000 camry, i bought all parts from toyota, for my 93 camry, i got it from autozone.
both changed about the same time. no problems from both cars
skewe is offline   Reply With Quote
japanese cars rank highest in reliability.. ToyotaMan1281 General Discussion 64 03-14-2007 07:19 PM
New Toyota Parts Website Toyota PartzGuy 2nd Generation (2000-2004) 12 03-14-2007 05:26 AM
Talk sh** all you want man Avalonman General Discussion 93 03-11-2007 01:18 PM
New Toyota Parts and Accessories Website Toyota PartzGuy Celica Forum 0 03-07-2007 01:20 PM
Parts compatibility Question GrantTPC Camry & Solara Lounge 2 06-04-2005 10:39 AM
