I need help with radio - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-21-2007, 10:55 PM   #1 (permalink)
View mike125sx's Photo Gallery
I have a 1996 camry but i need help on how to remove the toyota radio i think its something with removing the dashboard thing around it but i dont know forsure.
Thanks.
mike125sx is offline   Reply With Quote
Old 08-21-2007, 11:13 PM   #2 (permalink)
Lone star
blackhawk's Avatar
View blackhawk's Photo Gallery
ok here is what you need to do the plastic that hold the ciggaret liter in the U shaped thing put a flat head at the bottom and pry it out this should allow you to see 4 scrues un scru those and you shold be good
I HAVE NO IDEA HOW THIS WORKS
blackhawk is offline   Reply With Quote
Old 08-21-2007, 11:19 PM   #3 (permalink)
hey thanks for the info.
Old 08-22-2007, 09:35 AM   #4 (permalink)
Heat's Avatar
View Heat's Photo Gallery
Yeah, gently pop off that u-shaped piece of trim.
As for the four screws / bolts, when I removed my radio a couple months ago three of them were stuck - using a screw-driver was starting to strip them. So I just used a 10mm socket, they came right out. This was by far the easiest radio removal that I've ever done. And for the new kit you won't need a kit (assuming you have a pocket under your factory radio), a mounting bracket, or even a trim ring.
Heat is offline   Reply With Quote
Old 08-22-2007, 03:10 PM   #5 (permalink)
Gameroom cash: $303055
Just a tip on removing the u-shaped piece of plastic trim. Remove the lighter first. Then the 2 clips are at the bottom near each side. Get a j-hook tool or a dental pick under there near each side and pull it outward to release each clip. Then the top is slightly hooked under the upper portion of the dash; you will see what I mean after the bottom clips are released. Once the top is unhooked, reach behind the piece of trim and unlook the electrical connectors to the lighter and it's light and remove the piece of trim. Then you will see the 4 screws mentioned above. It really is an easy radio to remove.
Mike
Old 08-22-2007, 03:33 PM   #6 (permalink)
So I don't need a mounting kit only the one that came with the factory radio it has the storage box under it btw if that matters.
Old 08-22-2007, 06:36 PM   #7 (permalink)
'95 Camry V6 XLE
View eddie926's Photo Gallery
USA
These links might help you out.......
http://installdr.com/InstallDocs/Toyota/PDF/869013.pdf
http://web.archive.org/web/200302220...alToyCamry.htm
eddie926 is offline   Reply With Quote
Old 08-22-2007, 09:05 PM   #8 (permalink)
Heat's Avatar
That is correct, you don't need a kit. When you take out the radio you'll see a bracket that is holding the radio as well as the pocket. Take off the screws holding on the radio and the new radio should have holes in the same place, just attach it to the bracket and slide the thing back in.
When I did mine there were two very small tabs on top of the pocket that I pried off to make the pocket / radio fit together better, you'll see what I'm talking about when you get into it.
1999 camry radio problems LTJ 3rd & 4th Generation (1992–1996 & 1997–2001) 4 06-30-2009 10:17 AM
Question about XM Radio mstitswo 5th & 6th Generation (2002-2006 & 2007-2011) 9 02-27-2008 08:29 PM
Dual purpose radio? Mooch Audio, Video, and Security - Tech 5 05-19-2007 09:50 PM
Factory CD Changer radio replacing a Factory 1 CD radio jacksnodgrass 2nd Generation (2005+) 1 07-03-2006 06:06 PM
