I can smell petrol when i drive my other car - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-22-2007, 10:46 AM   #1 (permalink)
Found this name
View ejaymclane's Photo Gallery
When i drive my other car, a gen3 Maxima, with the windows open i can smell petrol throughout the cabin although its mainly in the rear.
The smell is like the smell of a petrol station, not the smell of exhaust fumes.
What could be causing this? The exhaust sounds ok btw.
ejaymclane is offline   Reply With Quote
Old 08-22-2007, 11:26 AM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
does the car drive fine? it sounds like a fuel leak. ull have to check the fuel rails, injectors and fuel line. chances are its near the engine so look for wetspots.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 08-22-2007, 11:32 AM   #3 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
sounds like you have a fuel leak. drive the car around and park it with the car running and crawl carefully underneither. a leak can from from one of the supply lines when the car is running, could leak from a rust spot in the tank or even where the filler neck connects. driving around just before you check (as long as you check it quickly, as petrol evaporates quickly) will hopefully leave a wet spot.
Old 08-22-2007, 11:53 AM   #4 (permalink)
Found this name
Ill have a look thanks.
Old 08-24-2007, 05:09 AM   #5 (permalink)
Found this name
Ok.
The fuel consumption seems normal.
I drove the car 40 miles yesterday, i could smell petrol anytime i opened the windows yet when i parked in the evening i looked under the car and saw no pools of anything, no dripping and i couldnt even smell the petrol smell around or under the car literally 30 seconds after parking.
Old 08-24-2007, 05:48 AM   #6 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
You don't need much of a leak to smell gas fumes. If the leak is small you will also not see any drips as it will evaporate first. I would take the car to a shop where they can use a sniffer for hydrocarbons and trace the leak. It sounds like it's coming from under the hood and only happens when the car has fuel pressure.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 08-24-2007, 10:00 AM   #7 (permalink)
I hate 5SFEs
conor's Avatar
View conor's Photo Gallery
You may not have a fuel leak.. it could be that you have a disconnected or cracked/torn line somewhere in your evaporative emissions control system. Your fuel tank probably has multiple breather lines coming from it, too, you'd definitely be smelling gasoline; especially when the car is running and you can't properly pressurize the tank(gasoline vapors would be continually expelled).
If you had a physical fuel leak, you'd probably see it on the ground beneath the car..
conor is offline   Reply With Quote
Old 08-24-2007, 10:56 AM   #8 (permalink)
Green Gang
View 213solider's Photo Gallery
the camry is sabatoging your maxima
Camry TRD
213solider is offline   Reply With Quote
A few vip camry pics MattSWE Camry & Solara Lounge 95 07-29-2008 09:43 AM
VIP cars 56k no wayyyy moky-tron 5th & 6th Generation (2002-2006 & 2007-2011) 16 07-29-2007 12:44 AM
For Sale: 1991 Toyota MR2 non-turbo automatic (many pics) LarryDallas Vehicles 2 07-07-2005 03:15 AM
Rough idle, gas smell, erratic drive blackaneseazn Celica Forum 13 01-23-2005 10:07 PM
car jerks when i put into drive crazy_camry Camry & Solara Lounge 18 08-22-2003 11:05 PM
