Stalled Now won't start! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-22-2007, 11:08 AM   #1 (permalink)
View dchohman's Photo Gallery
My 93 4 cyl camry stalled a couple of times the other day, and I was able to limp it home. After leaving it sit for a couple of days, now it won't start. It tries to start, but won't turn over. My first inclination is that it is not getting fuel. Pump? Filter? Anything else?
Thanks
dchohman is offline   Reply With Quote
Old 08-22-2007, 11:27 AM   #2 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
check the big three things - fuel, air and spark. if it stalled and you were able to start it right away, i dont think its the fuel pump. when those have gone for me, they would cut off, then after about 15 minutes, they would work again but only for a short amount of time and die again. take out one of the spark plugs (then ground the plug) and crank the car to see if it sparks. also poke around the throttle body to see if any vacuum hoses came off or broke. if you disconnect in the air intake from the TB, you can spray in some starter fuild and crank the car to see if that helps.
Old 08-25-2007, 03:38 PM   #3 (permalink)
View marc780's Photo Gallery
some possible causes - throttle body and iac very dirty (clean it); dead fuel pump; broken distributor shaft, or worn out cap and rotor (if your engine has a distributor); dead coil; MAF sensor dead; clogged fuel filter; worn out ignition switch; blown fuel pump fuse. (There are more things possible, unfortunately, but these are all i can think of at the moment)
What he said, find out whether it is spark or fuel that is missing. The first and easiest step - get a can of starting fluid, follow what the can says, see if the engine will run on it for a few seconds. If it does, you now know fuel is the problem, spark is ok and can go from there. If it doesnt even try to run, time to tear into the ignition system.
Old 08-27-2007, 10:13 AM   #4 (permalink)
UPDATE - Started first try Saturday morning and ran for a while on idle. Haven't tried to take it for any distance yet. Cleaned the throttle body while it was running.
2001 Tacoma won't start HotRodd38 1st Generation (1995.5–2004) 6 11-12-2007 03:44 PM
cold start issue any input/advice/suggestions would be appreciated.. xxpanipuri Camry & Solara Lounge 8 06-27-2006 07:39 PM
Engine won't start camree99 Camry & Solara Lounge 1 01-27-2006 06:41 PM
01 Rough Idle, Stall, Hard Cold Start anr 3rd & 4th Generation (1992–1996 & 1997–2001) 0 05-30-2005 12:50 AM
Click sound from under the hood..won't start snobdrblinkchik Camry & Solara Lounge 10 08-22-2004 09:04 PM
