Atf Type T-iv Ok? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-22-2007, 12:00 PM   #1 (permalink)
View NCCamry95's Photo Gallery
3rd Generation Atf Type T-iv Ok?
Question please...I ordered 6 qts of ATF for a fluid change from toyoautoparts for my Cam and I got Type T-IV, My owners manual calls for DexonII fluid for trans and power steering . Is the T-IV OK to use and is it better fluid that Dexon II?
Thanks in advance for the help,
RNB
Glad I don't have DBW
NCCamry95 is offline   Reply With Quote
Old 08-22-2007, 12:13 PM   #2 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
You cant use that stuff in your transmission. You have to stay with Dexron compatible stuff.
Should have checked BEFORE ordering.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 08-22-2007, 12:38 PM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
Dex III licenses ended Jan 2007, that's why it's getting harder to find. Use DEX III or the newer DEX VI.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 08-22-2007, 10:59 PM   #4 (permalink)
I checked several online vendors and "that stuff" is the fluid that they list for my auto. It is a syn. ATF fluid, So I did check before I ordered. Since my 95Camry is low milage ( 65,000) I am going to stick with Dexron II. You really must know a lot about Camrys since you have been able to accumulated 320,000 miles on yours.
Old 08-23-2007, 12:57 AM   #5 (permalink)
I work on euros.
View 96CamrySport's Photo Gallery
just call the dealer. dex 2 was pretty lax, I'd expect that t4 will fit the bill just fine.
1996 Camry Sport (that's a DX Coupe with decals) with 186k
european cars are just like japanese cars, just heavier and more expensive.
7 ASE's.
96CamrySport is offline   Reply With Quote
Old 08-23-2007, 01:41 AM   #6 (permalink)
Calm down there Sparky....dont get your panties in a wad.
When I said that you should have checked before ordering...i meant check here. There is a lot of useful info on this forum. Im still learning also....I never said I knew all there was to know. In fact...I just got this car from my dad about a month ago...those miles were from him and my step-mom...err ex-step-mom. Ive never even owned an automatic before...but ive been reading A LOT on these forums and other places to learn about the car. Mainly due to the fact that Im going to be doing a tranny fluid 'flush' soon, im trying to learn as much about that as possible.
Good luck with your car.
Old 08-23-2007, 03:03 AM   #7 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
Dex II was replaced by Dex III and you can use Dex III in Dex II applications.
As for Toyota's Type IV, I don't know whether that'll work or not.
2007 Camry 2.4L 5M
Old 08-23-2007, 10:55 AM   #8 (permalink)
I searched TN and found as many opinions concerning ATF as well....
Toyota dealer said I could if I was having problems with shuttering. Local Toyota Master Tech said iffy, I am going with touringcamry and using DexronIII. I don't want to take a chance on leaks using Toyota Brand Syn. Type T-IV ATF. My trans shifts like silk and I don't want to mess it up. I'll leave that to the Gen 6 drivers
Old 08-24-2007, 11:10 AM   #9 (permalink)
Help again. I purchased Castrol ATF multivehicle fluid that meets dexronII & III requirments. I emailed Castrol for assurance that this was the correct ATF for my car and the tech said yes, but I could not use it in the Differential! I am really confused now!!!
Please let me know what the TN thinks about this.
Thanks
RB
Old 08-24-2007, 01:10 PM   #10 (permalink)
Toyota specifies Dex III for the differential for Gen 3 automatics. You'll be fine.
You will also use Dex III for the power steering fluid. Castrol won't know every little detail about every model car out there. They'd rather err on the side of caution than get slapped with a lawsuit because the person gave a wrong answer.
2007 Camry 2.4L 5M
Old 08-24-2007, 11:09 PM   #11 (permalink)
Thanks for the answer. I phoned Castrol's 800# and spoke with a tech rep. He assured me that the ATF I purchased would indeed work in the three areas that you mentioned.
RB
ATF draining, how much refill? lakuen Archived Corolla threads 8 02-19-2007 09:46 PM
My Engine Oil & ATF Change routine modestobulldog Archived Corolla threads 10 01-31-2007 07:29 AM
2006 Rav 4WD ATF question JeffSav RAV4 Forum 3 01-08-2007 08:29 AM
Regular Dexron III automatic transmission fluid or Toyota ATF Type T-IV? 97&02camryleI4 Camry & Solara Lounge 2 01-12-2006 03:57 PM
Toyota Tranny fluid only? netranger6 2nd Generation (2005+) 11 10-11-2005 01:26 PM
