Help ASAP switching to reverse Gauges!!- FINISHED!! PICS ADDED!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-22-2007, 07:29 PM   #1 (permalink)
dpanda88's Avatar
iTrader Score: 7 reviews
View dpanda88's Photo Gallery
4th Generation Help ASAP switching to reverse Gauges!!- FINISHED!! PICS ADDED!!
OK I've done everything but the wiring part which is confusing... what do I do?? It says from DIY
Next run the wires from your location to the area where the gauges are installed. Note the bolt in the bottom center, it makes a very nice clean grounding point. This is a good point to get your 12v power source also. I used the green wire on the very right of the brown connector. It has a continuous 12v when the lights are on ONLY. The fuse box is nearby as well you may use that.
I see i have green and a black wire what am i suppose to do with those 2??
PLease HELP!
2009 Matrix XR @ 2.4L
[Mods] Megan Coilovers Gen 1 on Gen 2 [SLAMMED], Custom front lip, Magnaflow 14818 exhaust with 2.25" custom straight pipe, XRS 09 FSB, TRD RSB, K&N Typhoon Intake, Ichiban 15mm Spacers, XRS 09 18" RIMS on BFGoodrich G-Force2
dpanda88 is offline   Reply With Quote
Old 08-22-2007, 07:53 PM   #2 (permalink)
dpanda88's Avatar
where do i connect the wires? theres a black one and then theres a red/green wire?
Old 08-22-2007, 08:05 PM   #3 (permalink)
xet
View xet's Photo Gallery
take the ground wire and run it to the bolt in the middle i wrapped mine around the bolt as best i could and screwed it down as tightly as possible.
take the power wire and cut the green wire on the brown connector and splice the 2 pieces of that wire and the power wire for the gauges together. Some people like to use a T tap or w/e its called to be safe but I just put all 3 together and taped around it
1998 camry xle v6 *no longer mine*
2005 G35 coupe 6mt
xet is offline   Reply With Quote
Old 08-22-2007, 08:19 PM   #4 (permalink)
dpanda88's Avatar
ok so i get the black wire now .. as for the green.. when you say 2 pieces? is that the wire from the guages wires to the car wires?
I only have 2 wires.. the black and the green which is to plug into somewhere beside the grounder
Old 08-22-2007, 09:09 PM   #5 (permalink)
xet
Ok for the power wire for the reverse gauges which you want to connect to the constant 12v source.
First you locate the green wire on the brown connector at the end and you have to cut it in half. Then you have to strip back the wire on your power wire for the gauges, as well as the 2 pieces that you have from cutting the 12v source wire in half. Now you put them all together and twist them so they stay and then put electrical tape or something like it around them.
Then you just attach the ground wire to the screw in the back and when you turn on your headlights it should all turn on.
2005 G35 coupe 6mt
Old 08-22-2007, 10:16 PM   #6 (permalink)
dpanda88's Avatar
YES ITS DONE!! I just did all the wiring and it turns on great and everything else! Going to take a pic right now
Old 08-22-2007, 10:23 PM   #7 (permalink)
dpanda88's Avatar
Here's the finish!! It's not yet put back into spot.. as its dark and no light to see. .so i'm going to put it tomorrow morning.
Here;'s the pics!!
i wanna thank mzfe5speed for this awesome TRD gauge!
and XET of course for this help on wiring!! couldnt do it without his help!
Old 08-22-2007, 10:40 PM   #8 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
thoes are nice man. if i cared about my interior id do that, but thats what dark tint is for
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 08-22-2007, 10:50 PM   #9 (permalink)
dpanda88's Avatar
haha yeah.. i'm planning to do it this sat morning... waiting in line
Old 08-23-2007, 01:44 AM   #10 (permalink)
EvoFire's Avatar
View EvoFire's Photo Gallery
3 colors?
EvoFire is offline   Reply With Quote
Old 08-23-2007, 01:48 AM   #11 (permalink)
PICKLE GANGSTER
Rdizzle's Avatar
iTrader Score: 6 reviews
View Rdizzle's Photo Gallery
I've said that for years
Why do a complete interior for like 2 grand when you can get the same effect with 5% limo tint
Originally Posted by DarkMastyr View Post
Is it just me, or has TN just become this massive gay fest? It's like you can't avoid the hot gayness in every thread.
[U]
http://www.cardomain.com/ride/398065...ry-le-coupe-2d
Rdizzle is offline   Reply With Quote
Old 08-23-2007, 03:53 AM   #12 (permalink)
View 94CoupeV6's Photo Gallery
Wow, I really like those and the TRD in the middle is cool. Look way better then my reverse gauges.
94CoupeV6 is offline   Reply With Quote
Old 08-23-2007, 11:29 PM   #13 (permalink)
View built2burn's Photo Gallery
how well can you see the needles b/c it looks like you can barely see them
built2burn is offline   Reply With Quote
Old 08-24-2007, 08:01 AM   #14 (permalink)
dpanda88's Avatar
yeah I was about to ask everyone how can i fix this problem. The gauges light up perfectly but now at night time the KM of how much I have went doesnt light up and my needles doesnt light up either. Even though its not a BIG problem to me but I would prefer it to light up. Anyone have suggestions? All i did was cut the green wire on from the brown connector and put together does wires with the wire from the gauges all together and grounded the black wire to the bolt thats inside the dash.
Old 08-24-2007, 10:54 AM   #15 (permalink)
Green Gang
View 213solider's Photo Gallery
i don't tend to like reverse glow gauges cuz in day it's white and look ugly but at night all the show start when the colors come to live.but anyways the trd logo look very clean.
Camry TRD
213solider is offline   Reply With Quote
01 camry reverse glow gauges stuntking40 3rd & 4th Generation (1992–1996 & 1997–2001) 3 11-11-2005 02:46 PM
Installing Reverse Glow Gauges blkdmnrcing Camry & Solara Lounge 2 08-20-2005 09:20 PM
? re: Reverse Glow Gauges Beez97Cam Camry & Solara Lounge 29 12-16-2004 02:31 PM
Reverse Glow gauges 1999 Camry kdrk 3rd & 4th Generation (1992–1996 & 1997–2001) 11 04-02-2004 05:18 PM
Reverse Indiglo gauges .. lilkevie Camry & Solara Lounge 10 10-05-2002 04:41 AM
