Passenger Cv axle/ rear motor mount trouble? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-26-2007, 11:17 AM   #1 (permalink)
View Yaserk88's Photo Gallery
Hey My passenger side axle is stuck in the rear engine mount bracket. I have taken the four bolts on the bracket and the nut on top of the motor mount. The only problem is that the motor mount is not coming out. I have even taken out the nuts at the bottom of the mount on the chasis, but the bolts going through the chasis will not allow me to free the mount and bracket. I think the bracket is stuck to the top of the mount where the single nut goes. Anyone have an ideas besides alot of PB blaster?
Yaserk88 is offline   Reply With Quote
Old 08-26-2007, 02:14 PM   #2 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
is this for a 4cyl camry??
i managed to take my axle out with the rear engine mount, rear engine mount bracket attached.
here is what i did,
i took off the dogbone, loose bolt on front engine mount, loose bolts on radiator, and disconnect a few ground wires. then put a 2x4 stud at engine oil pan, jack up the engine by oil pan, just jack up slowly and watch stretch on all hoses and wires
the top bolt at rear engine mount has little room to put wrench there, that is why i took the whole thing out.
bronzemaxell is offline   Reply With Quote
Old 08-26-2007, 09:58 PM   #3 (permalink)
rusty9's Avatar
Gameroom cash: $440405
View rusty9's Photo Gallery
yeah thats pretty much the only way to do it. when i replaced mine, i loosened the rear mount bottom bolts too to give me extra wiggle room while raising and lowering the engine to wiggle the damn thing out. what a pain in the ass. after all that, i still had to use an 8 pound sledge to beat the axle from the carrier housing.
rusty9 is online now   Reply With Quote
Old 08-28-2007, 08:33 AM   #4 (permalink)
I will give it a try and let you guys know how it goes. Thanks.
1mz fe passenger cv axle removal amekaji87 3rd & 4th Generation (1992–1996 & 1997–2001) 9 06-09-2007 08:47 PM
Rear Axle Leak tucson4runner 4Runner Lounge 0 03-14-2007 01:57 PM
CV axle seal dixiestripes350 1st Generation (1995.5–2004) 1 07-31-2006 08:42 PM
passenger side cv axle bowlofturtle Camry & Solara Lounge 7 05-31-2005 05:19 AM
rear axle trouble Skeetzilla Archived Corolla threads 0 05-24-2003 09:01 PM
