Download the generation 4 Toyota factory service manual that is stickied at the top of the General Camry Discussion forum. It is available for free downloading. Go to the section covering the fuel system. It should have the instructions you need.
This is a relatively easy thing to do. Basically you remove the back seat cushion by lifting up from the bottom. You will see an access plate with 4 screws covering the pump area. Remove the 4 screws and the plate. Disconnect the electrical connector. There will be a large ring holding the pump in. You must drive the plate in a counterclockwise direction. Using a slotted screwdriver and a hammer usually works. Next remove the pump itself. You have to lift and manipulate it a bit to get it out. You usually have to transfer the in-tank filter (also called the sock) on to the new pump. Installation is the reverse of the removal procedure.
Mike
