You may find that the cover of that third brake light comes off from the inside and gives access to the bulb. There should be a plastic rivet type clip on either side that has a center pin in it. You just push the center pin in and the clip releases. Pull the clips out and pull the cover off. To re-install just pull the center pin out past the surface of the clip head, install the clip and push the center pin flush with the top of the clip.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
