Small fuel leak at the filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-26-2007, 10:17 PM   #1 (permalink)
View Silver99camry's Photo Gallery
Hi,
I replaced fuel filter over the weekend with a genuine Toyota peice and now I a small fuel leak. It leaks where hardline from the pump attached to the filter. No matter how hard I try to tighten it, I cannot eliminate the leak. It's not a lot, no fripping fuel or anything like that, but if I get under the car with the engine running I can see the fitting getting wet within a minute or so. Has
anyone had a similar problem? How do I fix something like that? I guess I am not sure why it leaks. I tightened it pretty good. I am going to take it apart again, clean the surfaces, apply anti-seize on the threads and try one more time. Any other suggestion what I should check or do when it's apart? Is it possible for a small leak like that to go away by itself with time?
Thanks
99 Camry 2.2L
Silver99camry is offline   Reply With Quote
Old 08-26-2007, 10:55 PM   #2 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Do the filters come with crush washers? If so...did you use them?
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 08-27-2007, 12:31 AM   #3 (permalink)
Crush washers are for the top eye bolt. The bottom connection does not require any washers, it attaches to a flared hard line. Bottom connection is leaking for me.
99 Camry 2.2L
Old 08-27-2007, 06:09 AM   #4 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
I'm wondering if you cross threaded the bottom connection so you are not getting the proper compression of the pipe flare? I would remove the filter and check the filter threads as well as the flare nut threads. It can be tricky to get those flare nuts started, but it's very important to start them by hand to make sure the threads are not crossed.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 08-27-2007, 10:24 AM   #5 (permalink)
I'll double check that but I did it by hand for the first 3 or 4 full turns.
Thanks
99 Camry 2.2L
Old 08-27-2007, 08:07 PM   #6 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
i would think its the o-ring aka washer.
i did that for my freiend's gen 2 solara. same issue like yours.
I have changed 2 fuel filters for camry and 1 unsuccessful solara
skewe is offline   Reply With Quote
Old 08-27-2007, 08:52 PM   #7 (permalink)
Official TN PimP
Dawgz's Avatar
View Dawgz's Photo Gallery
i had the SAME problem, what did the trick is taking the filter off, and wrapping the thread with Teflon tape, just the thread area, one wrap, not multiple times, and then screw it on, im telling u that 100% ur leak will be gone.
Blah
Dawgz is offline   Reply With Quote
Old 08-28-2007, 10:17 AM   #8 (permalink)
Interesting idea. Is teflon tape safe to use with gas? I might try it.
99 Camry 2.2L
Old 08-28-2007, 10:18 AM   #9 (permalink)
As far as I know there is no washer for the bottom connection. There are 2 washers for the top connection though. Please correct me if I am wrong.
99 Camry 2.2L
Old 08-28-2007, 10:53 AM   #10 (permalink)
The bottom connection is a flare nut fitting with straight threads. It seals by compressing the tube flare to the mated connection on the filter - NO sealing is required of the thread as the thread only compresses the fitting to do the sealing.
Old 08-28-2007, 03:00 PM   #11 (permalink)
Official TN PimP
Dawgz's Avatar
yes its safe, i used it on my fuel lines to the fittings at the Fuel Rail as well.
Blah
Old 08-28-2007, 11:20 PM   #12 (permalink)
Thanks man! It fixed my problem! Car is back on the road.
99 Camry 2.2L
Old 08-29-2007, 12:18 AM   #13 (permalink)
Official TN PimP
Dawgz's Avatar
good to hear!
Blah
Question on fuel filter replacing tonysun23 3rd & 4th Generation (1992–1996 & 1997–2001) 36 05-14-2008 12:02 PM
K&N: Why take filtercharger over drop-in filter? dELuX-4x4 2nd Generation (2005+) 88 10-02-2007 01:13 AM
Want better engine performance?? CHANGE THAT FUEL FILTER! REAPER STRAIN Camry & Solara Lounge 24 01-20-2006 03:07 PM
Changing the Fuel Filter.... teamer Camry & Solara Lounge 8 08-25-2005 11:15 AM
