Coolant Hosing Help.. - 97 Camry (Maintenance) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-29-2007, 07:54 PM   #1 (permalink)
View FishyMan's Photo Gallery
Hello,
I keep with the usual changes but since I am at it, I mgiht as well spend a bit more and change more things at once. I want to change the coolant.
Are there any suggestions for maintenance? I am wondering what ATF I should be using. Would MOBIL 1 be too slippery?
The car has about 50k and although it isn't that high in mileage, I am hoping to change some of the major hoses. However, I am unfamiliar with the name of some of them and whether or not it is easily accessable.
Thanks.
FishyMan is offline   Reply With Quote
Old 08-29-2007, 10:10 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
if you are doing your basic rad hoses, then they should all be available (usually as cut-to-fit) at your local auto stores....but be very careful as they never seem to seal quite as well as the oem hoses. for the bypass hoses, they are only found at the dealer (but I doubt you're changing those anyway).
and mobil 1 synthetic atf will work just fine.
but in reality....your car is really still in its infant stages....so you shouldn't have to worry about changing any hoses at all
HaHa
Old 08-29-2007, 10:13 PM   #3 (permalink)
Thanks for the reply.
I'm planning on doing a coolant drain/refill and since I'm gonna be doing so, I might as well change the 2 major hoses and thermo.
I tried locating the thermo, is it right above/near the oil filter?
I did the usual maintenance, but I see some oil around the valve cover, and I couldn't locate how, or what screws to access it?
1996 Camry radiator coolant disappearing? RAV4EVR 3rd & 4th Generation (1992–1996 & 1997–2001) 8 06-21-2006 12:13 AM
Low Fuel Indicator Light on '97 Camry? Camry97LE 3rd & 4th Generation (1992–1996 & 1997–2001) 5 05-28-2006 06:09 AM
60K maintenance for '97 V6 Camry 97V6CamryGirl 3rd & 4th Generation (1992–1996 & 1997–2001) 6 03-31-2004 10:56 PM
