Little leak around driver side drive shaft - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-29-2007, 08:23 PM   #1 (permalink)
Den
86 Celica Gt driver
View Den's Photo Gallery
Canada Little leak around driver side drive shaft
Okay guys, I need some help here, My camry has a little leak around the drive shaft.
I am wondering what kind of oil is leaking? Motor Oil or transmission oil
also, it is just a very minor leak. like a few drops. Should I do anything do it?
thx~
1993 Camry LE "5 spd" with 410k + ... still going~!
1985 Celica GT
1986 Celica GT "GONE"
Den is offline   Reply With Quote
Old 08-30-2007, 01:15 AM   #2 (permalink)
KRISREBISZ
View rebiszkrzys's Photo Gallery
Hi there. I think you might have a problem that I just recently had with my 96 5sfe camry. My leak was from left/drivers side drive shaft. I t wasn't too bad visually but every single time I parked somewhere for a couple of hours there would be a few drops on the ground afterwards. I got underneath the car, examined where the leak was coming from and for 99% I was sure that it was a axle seal leak. I decided to change it because it might actually cause a lot of damage in a long run. If you think about it, when you get a few drops while your car is parked how much oil is actually leaking when you drive and when preassure rises??? Probably way more. Differential doesn't hold as much ATF as transmission does so you may easily run out of fluid after a while and than you f...ed.
But guess what...... It was a bitch to get it replaced and I hope that I wont have to do it ever again in my life. Axle wouldnt come out and etc. So hopefully this isnt your case but look into it carefully. Leaks arent a good news sometimes.
Seal was only about $11 and I also replaced the inner boot($13) cause it had a little hole in it. Whole project was worth it though. No more leaks and I also changed differential fluid, I droped AT fluid pan, replaced gasket, cleaned filter out and replaced transmission fluid. Dirty job though but i like it sometimes so good luck man.
rebiszkrzys is offline   Reply With Quote
Old 08-30-2007, 06:06 AM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
As rebiszkrzys said it sounds like the axle seal, leaking oil s/b red(ish). I would check your differential oil level. That's the real potential for damage; running the diff oil too low. Easy - replacing them, Hard - getting to them. It would be nice to wait until you need a new cv as the axle has to come out anyway. As long as you keep track of your diff fluid level you will be ok.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 08-30-2007, 08:08 PM   #4 (permalink)
Den
86 Celica Gt driver
Canada
man.. pain in my ass
I just changed the engine.. ouch!
by the way, where can I check my diff oil? I have 3vzfe and manual
I got no clue how to check my diff oil
aw... I don't want to spend too much.....
1985 Celica GT
Old 08-30-2007, 08:10 PM   #5 (permalink)
The Greek....
GrkBallaG's Avatar
iTrader Score: 13 reviews
View GrkBallaG's Photo Gallery
You dont, theres two plugs, a drain and a fill.... theres no stick like an automatic has.
The SLAMry.....
Slammed, Carboned, 5sp Swapped, Big Braked, RMM Lipped And Ready To Be Daily Driven!
Originally Posted by UfoZ View Post
Tits! Best non turbo Camry there is.
GrkBallaG is offline   Reply With Quote
Old 08-30-2007, 09:35 PM   #6 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
You should be able to check your diff like on a 4 cyl auto (they have separate diff cases from the tranny). The fluid should be up to the fill plug on the back side of the diff. I don't know about the manual transmission but on the autos the dif fill plug took a 17mm wrench/socket.
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 08-30-2007, 11:39 PM   #7 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
it's a 24mm on the e153
HaHa
Old 08-31-2007, 12:19 AM   #8 (permalink)
Den
86 Celica Gt driver
how much approx will cost me if i want to fix the problem?
1985 Celica GT
Old 08-31-2007, 01:09 AM   #9 (permalink)
KRISREBISZ
By yourself or at the shop? By yourself $30-$50. A the shop roughly $200.
1997 Corolla 7AFE
2004 Toyota 4runner V8
2001 Lexus GS430
Feeler post on TW one piece drive shaft group buy. russ25nys 2nd Generation (2005+) 30 04-05-2007 12:32 AM
New IIHS side crash tests: Crown Vic, Fusion, Freestyle, FJ Cruiser IFCAR General Discussion 0 09-14-2006 06:45 AM
Avalon and Impala score best among IIHS side crash test results for large sedans IFCAR Toyota News 1 06-24-2006 05:28 AM
could you get away with it bondobondo General Discussion 46 07-06-2002 12:00 PM
