94 Camry Questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-30-2007, 09:42 AM   #1 (permalink)
View unkit's Photo Gallery
3rd Generation 94 Camry Questions
Hi guys.
I read almost all of ur posts and I thought I might ask a question. I've got a 94 camry CSI (Australian). I'd like to improve a few things in the car if possible (It has 250 000km on it, and the previous owners don't appear to have looked after the car at all, so i don't wanna spend too much on it)
  • My car is always cold for about 5km of driving. (I've had coolant, thermostat etc replaced).
  • Oil leaks - I've had the rear main fixed, the filter gasket replaced, etc... but there r still 2 leaks... One seems to be a clear oil and the other is engine oil... any common leaks that it might be?
  • Right hand rear window winder is shot, the plastic appears fine, is there a trick to wind the coil properly inside the regulator?
  • One of my headlights has moisture inside. Is there a way to open it and clean it out?
Thanks for all your help. Thanks to this site, i was able to replace all the globes in my dash to working ones.
unkit is offline   Reply With Quote
Old 08-30-2007, 11:23 AM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
- the cooling issue is pretty common with these cars. they take a while to get to operating temp.
- head gaskets and valve cover gaskets are major culprits, especially that valve cover one.
- manual windows IDK
- if u want u can heat up the adhesive that holdds the lense on the housing of the lihgt and then it will come off so u can clean it. preheat the oven to 250 degrees then turn off the oven, place the headlight in and wait about 5-10 mins the adhesive should be warm enough to just pry the lense off. remember to take the 6 clips binding the lense to the housing off. do the same to seal them again.
hope this helps
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 08-31-2007, 08:12 PM   #3 (permalink)
Thanks a lot, i'll have the valve cover gasket checked out asap.
I was reading up on engine sludge on these cars being quite common. Could this be the reason it takes so long to warm up?
Old 09-01-2007, 12:24 AM   #4 (permalink)
Expat Kiwi Afficianado
RodMillenFan's Avatar
View RodMillenFan's Photo Gallery
Before I tried to wind up the old regulator, I'd look on eBay. They sell 'em new for cheap, and you'd be more assured it's done right. It's a bit of a fuss to install, and I'd hate to get it all done only to have it go out again in a month.
The 'clear' oil... is it reddish amber, coming from the passenger side of the engine bay? In our 92 and 93 V6's, that's a power steering pump leak. You might consider that.
Good luck!
Originally Posted by unkit
Hi guys.
1992 Camry SE V6 5M, Dark Emerald Pearl (Japan Build)
1993 Camry SE V6 4A, Sunfire Red Pearl (Kentucky Build)
2007 Camry SE V6 6A, Barcelona Red Metallic (Kentucky Build)
Okay, okay, so two are actually my wife's cars...
RodMillenFan is offline   Reply With Quote
Old 09-01-2007, 09:35 PM   #5 (permalink)
3rd Generation thanks for ur reply
I've tried finding the window regulators on ebay... Never any success.
By clear, i meant see through and colourless oil. Its def not water, cause it leaves a stain... but not sure what it is.
Thank you guys so much for your replies, I really appreciate it.
What colour is diff oil?
Old 10-29-2007, 02:44 PM   #6 (permalink)
View MrCamryWagon's Photo Gallery
Thought I'd just latch onto this thread instead of starting a new one-
So this weekend I had to replace a light on my '95 wagon. Bought the 9006 55 Watter for the outside lamp, and began to take off the lens of the light as I wrongly thought I'd have to. However, after having removed the 4 clips I could see (and 2 of them are down on top of the bumper- no idea how I'd put them back on) - I realized the lense was pretty solidly anchored with epoxy and/or essentially welded to the headlight housing. So looking at the book I had I realized- DUH! - I have to pull the light out from inside the hood behind the lamps. That done and the lamp successfully replaced, I had to wonder if the 2 clips I can now no way get back on are really of any value to holding the lense on. It seems they must function as temporary clips until the factory bonding dries/cures the headlight ssembly. Is this right?
MrCamryWagon is offline   Reply With Quote
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
Fusion marches past Camry! sciguy0504 Camry & Solara Lounge 38 05-04-2006 06:27 AM
2000 camry questions dimask 3rd & 4th Generation (1992–1996 & 1997–2001) 4 03-06-2006 09:14 PM
few questions about changing stuffs in 2002 Camry LE chjvc 5th & 6th Generation (2002-2006 & 2007-2011) 1 07-06-2002 03:13 PM
