dash trim - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-30-2007, 05:02 PM   #1 (permalink)
View luckycharms's Photo Gallery
dash trim
hey so yeah my girlfriend has i beliieve a 96 0r 96 camry annd i was gunna take the dash off to work on her radio but im a dodge guy and have no idea how to get the trim around it off, it looks like its all one piece from around teh radio to around the guages, and i wondering it its just like screwed in a few spots and then un clips im lost
luckycharms is offline   Reply With Quote
Old 08-30-2007, 05:05 PM   #2 (permalink)
Experience>Post Count
View MIC0417's Photo Gallery
Pull out the cigarette lighter and try to yank the little piece off, then you just wire whatever up, it's just that one piece
MIC0417 is offline   Reply With Quote
Old 08-30-2007, 05:21 PM   #3 (permalink)
wait yank what little piece off?
Old 08-30-2007, 05:22 PM   #4 (permalink)
'95 Camry V6 XLE
View eddie926's Photo Gallery
Here ya go....
http://installdr.com/InstallDocs/Toyota/PDF/869013.pdf
eddie926 is offline   Reply With Quote
Old 08-30-2007, 05:22 PM   #5 (permalink)
that the lighter is connected to
Old 08-30-2007, 05:26 PM   #6 (permalink)
so the thing the ciggarette goes into is like stuck in there its not clipped or whatnot i just kinda pull?
Old 08-30-2007, 05:28 PM   #7 (permalink)
you could look at the directions that eddie put up and try it yourself
Old 08-31-2007, 11:31 PM   #8 (permalink)
Gameroom cash: $303055
There are 2 clips that hold that U-shaped trim piece surrrounding the radio and climate controls on. They are on the bottom at each side. I found it best to use a dental pick or a j-hook tool to loosen the clips. Stick the j-hook tool or dental pick under the bottom at each side and pull towards the back of the car. It will release the clip. Then remove the top portion of the trim piece by pulling in and down; it just hooks on a lip under the piece above it. Now reach behind and disconnect the wiring to the cigar lighter and the light surrounding it. The trim piece is now free. There will be 4 screws (usually phillips hex-washer head screws) holding the radio in to it's cage. Remove the screws and pull the radio forward. Reach behind it and disconnect the electrical connectors and the antenna. The radio is now free.
Mike
New 2005 Toyota Avalon Unveiled! Ratko Toyota News 64 05-04-2005 12:14 AM
need help for replacing LED for dash trim in 5th gen camry butho33 Camry & Solara Lounge 2 01-21-2005 12:34 PM
Trim Modification Speshull Droo Audio, Video, and Security - Tech 7 01-07-2005 12:48 AM
My dash lights went out! xavior66 Camry & Solara Lounge 5 08-03-2004 01:38 AM
dash trim EKCamryLE General Discussion 1 03-05-2002 07:28 PM
