radiator replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-31-2007, 12:44 PM   #1 (permalink)
View imbest123's Photo Gallery
4th Generation radiator replacement
how hard is it to replace the radiator? also what tools will i need? thank you!
Bolt ons are so yesterday
imbest123 is offline   Reply With Quote
Old 08-31-2007, 06:04 PM   #2 (permalink)
Toyota Camry Vienta CSi
View Aussie_Camry's Photo Gallery
Its prity easy, I did it a while back with no real mechanical knowledge, just get a good repair book or get one online. Issues I will highlight for your benefit that I encountered (nothing major), varies on which car you have exactly... but:
* Seperating fan assembly from radiator, bolts were corroded on badly, so have something on hand to spray and loosen them... also abit of brute force helps. I ended up soaring one of the bolts off and replacing it because it just wouldnt move.
* Have plenty of towels on hand. My 3VZ has a hydraulically operated fan which uses the powersteering fluid, so when you undo the bolt for it alittle fluid (tranny fluid is used so top it back up) will spill unless of course you have the other type of fan.
* Get yourself two reasonably sized bolts, compare it to the tranny cooler lines running through radiator... use them to plug the cooler lines up so you dont have to refill tranny. I did this, backyard mechanic style... but it meant that I didnt have to touch the transmission, one less thing to worry about.
* Once its fall done, refill with coolant... then make sure you bleed the air out of the system by filling the coolant all the way up, then leaving the cap off turning the engine on and letting it heat up...add coolant as it goes down. Also make sure its all ok by checking it a week later.
Aussie_Camry is offline   Reply With Quote
Old 08-31-2007, 08:08 PM   #3 (permalink)
Banned
View kurtdaniel's Photo Gallery
please visit this if you want info bout radiator repair and maintenance -- http://www.howtodothings.com/automot...-radiator.html toyota avalon radiator
kurtdaniel is offline   Reply With Quote
Old 08-31-2007, 08:16 PM   #4 (permalink)
lol thanks guys but i already replaced it. took me no more than an hour, it was super easy. thanksguys~
Old 08-31-2007, 08:19 PM   #5 (permalink)
Banned
good job, congrats
