A/C drain tube keeps getting clogged... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-01-2007, 03:54 PM   #1 (permalink)
toyocam99's Avatar
Gameroom cash: $118835
View toyocam99's Photo Gallery
My A/C drain tube gets getting clogged and the water is overflowing into the car on the drivers side. I've put a shop vac up to it a few times to suck out whatever's stuck, but it clogs a few days later. Does anyone know how to unclog it? I tried searching and found this: http://www.toyotanation.com/forum/t151023.html
But I don't know if that's what's wrong.
Thanks in advanced.
toyocam99 is offline   Reply With Quote
Old 09-01-2007, 04:12 PM   #2 (permalink)
View toyomoho's Photo Gallery
The evaporator causes water vapor to condense on its outside. This water runs down to a pan to collect. The pan has a drain pipe that runs out the bottom of the car. The pipe can become plugged. You will need to get under the car to see the pipe then try cleaning with a rod, etc.
Old 09-01-2007, 04:34 PM   #3 (permalink)
Experience>Post Count
View MIC0417's Photo Gallery
I don't use A/C But seriously I think toyomoho has a very good solution, it would explain why it keeps overflowing, because you're just collecting water thats been building up but not clearing the clog
MIC0417 is offline   Reply With Quote
Old 09-01-2007, 05:32 PM   #4 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
He already knows WHY it's overflowing, because he said hehas cleaned the drain tube out before but it keeps getting clogged....I think he wants to know how to keep it UNCLOGGED...right?
When you used the shop vac...did you open up the shop vac after you unclogged it to see what was in there?
When I opened up my evaporator housing on my 92 accord a year or so ago..there was leaves and stuff in there.....stuff like that can cause the clog. You may want to pull it out and clean it with compressed air or something...and make sure nothing is sitting in the bottom of the "collect pan" that could cause the clog...like mud from the water mixing with the dirt.
Good luck.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 09-01-2007, 11:19 PM   #5 (permalink)
toyocam99's Avatar
Good luck.
Exactly, I know it's clogged and tried to clear it today with a pipe cleaner and the shop vac. I looked in the shop vac container and didn't see anything, but I didn't really look that good.
How do you open up the evaporator housing on a 99 camry, cause I don't even know where it is. Hopefully the pipe cleaner cleared it, but you'll probably hear from me again if it gets clogged.
Thanks Again.
Old 09-01-2007, 11:53 PM   #6 (permalink)
Thanks Again.
Well...on my 92 accord....I opened it up when I had my whole front end off the car and had the whole a/c system down and apart. With your's still charged with freon...im not sure..but maybe someone else will know if you can or not.
Old 09-01-2007, 11:55 PM   #7 (permalink)
toyocam99's Avatar
Hopefully, thanks for your help though.
Old 09-02-2007, 05:53 PM   #8 (permalink)
View lenjack's Photo Gallery
This clogged on my '98 for the 4th summer in a row. Instead of paying a shop to clear it, I decided to give it a try myself without lifting the car. I thought the drain would be hard to find, but by putting a mirror on the ground I found it easliy, and was able to reach it and clear it in seconds. If you put your head on the ground behind the front wheel (passenger side), you can see the drain without the mirror.
lenjack is offline   Reply With Quote
Old 09-02-2007, 06:19 PM   #9 (permalink)
toyocam99's Avatar
I've found the tube and have cleared it, but it keeps clogging, literally within days of clearing it. Does anyone know how to clear it permanently?
Old 09-03-2007, 08:23 AM   #10 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
You might want to use something stouter than a pipe cleaner. I've used a piece of coat hanger bent over double on the end so as not to have a sharp point. Works well.
FWIW
YMMV
DFBonnett is offline   Reply With Quote
Old 09-03-2007, 08:33 AM   #11 (permalink)
A dilute solution of water and household bleach would probably clear up any fungus or mold. ... Not exactly sure how you would get any of it through the drain tubes .... Maybe a siphon hose .... it would all eventually drain out.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 09-03-2007, 09:09 PM   #12 (permalink)
yeah...i do that through the drain system for the a/c in the house. Works well.
Old 09-11-2007, 09:58 AM   #13 (permalink)
toyocam99's Avatar
well... it's been a week and it just clogged again. does anyone know how to unclog it permanently, i'm getting tired of always having to use a vacuum to clean it.
Old 09-11-2007, 10:18 AM   #14 (permalink)
Unless you get in there and find out WHAT is clogging it...then it's going to keep clogging.
Old 09-11-2007, 10:21 AM   #15 (permalink)
toyocam99's Avatar
that's the thing, i don't know how to get in there and find out what is clogging it. i'm in college, don't have too much money, and basically no resources.
Wet Carpet: Clogged A/C Drain? Brown Bear 1st Generation (1995-1999) 12 09-14-2006 01:56 PM
01 a/c wet carpet not rubber tube drain. help babuga 3rd & 4th Generation (1992–1996 & 1997–2001) 6 08-15-2006 03:03 PM
90 Camry LE V6 a/c orifice tube jORGE 1st & 2nd Generation (1983–1986 & 1987-1991) 0 08-10-2004 05:55 AM
