car won't hold alignment
1994 LE 5S-FE. I've had trouble with the outer edge of the front left tire wearing. I've had it aligned 3 times in the last 9 months and each time the toe-in was out, on the negative side ie. toe'd out. Usually both front wheels are out of spec. I recently had the front end apart replacing the drive shafts and did not see anything abnormal with the steering tie rod ends that could cause this. The lower control arm bushings on the sub-frame seemed to be old and cracked, but that was the only thing that I could see wrong.
Any ideas?
