Calliper Brake Bolt Removal Woes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-03-2007, 11:23 AM   #1 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
Bah this happens to me every time i try to change discs on any vehicle...there's always that ONE bolt that just won't ever come off unless i bring it into a shop with airtools.
I've tried breaker bar, wratchet with mallet/hammer combo and brute force. Hell the bit is showing wear already, but the bolt is still good.
Are there any suggestions on what i can do or use to remove it?
- Upper calliper bolt to remove the entire calliper and braket.
Thanks TN'ers!
nodrogkam is offline   Reply With Quote
Old 09-03-2007, 03:07 PM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Torch heat? Anti-seize should be your friend.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 09-03-2007, 03:12 PM   #3 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
torch! or go to a buddys with air tools ? deff anti-seize when you re assemble
CamrySExxx is offline   Reply With Quote
Old 09-03-2007, 03:37 PM   #4 (permalink)
I was trying to remove a nut on some metal shielding next to an exhaust manifold yesterday. It must have been rusted .... probably shouldn't have tried to work on it since it was still warm. I rounded the edges of the nut with the correct wrench, and vice grips just ground away what was left of any facets. Finally, I got a reasonably sharp prick punch and placed it on a spot towards the outer edge ... so that the punch blow would loosen the nut. After several hammers on the punch, the nut broke loose. The sharp point of the punch was able to dig in and grip the metal that was still there. I guess it was the jarring or impact of the punch that was able to make a difference. .... Might work on your bolt.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 09-03-2007, 03:53 PM   #5 (permalink)
aja8888's Avatar
View aja8888's Photo Gallery
A little PB Blaster and some time may get the corrosion free. Then hit it with everything you have again.
aja8888 is offline   Reply With Quote
Old 09-03-2007, 04:33 PM   #6 (permalink)
The Greatest
View CamNub's Photo Gallery
If you round it, best bet is to hammer something that is 1 mm smaller onto the old one.
CamNub is offline   Reply With Quote
Old 09-03-2007, 04:35 PM   #7 (permalink)
nodrogkam's Avatar
Thank you. PB blaster will probably be my route. I dont want to pay for more installation fees...
and they never used antisize on the bolts, but whatever...i'll see how it goes...
Old 09-03-2007, 04:38 PM   #8 (permalink)
The Greatest
You just need to break it loose. Once it gets loose, you're in good shape.
But get the anti-seize and if you brake a bolt, don't drive the car until you get new ones.
Old 09-03-2007, 05:04 PM   #9 (permalink)
nodrogkam's Avatar
hah duhh! thanks for the info tho.
for a camnub u have an aweful lotta posts...
Old 09-03-2007, 05:11 PM   #10 (permalink)
The Greatest
Use a wrench and not a ratchet when you're hammering it.
Old 09-03-2007, 07:34 PM   #11 (permalink)
nodrogkam's Avatar
lol i know i should...but hey...im just breaking cheap wratches left n right....hahah
well pb worked, everythings off, cleaned and begning painting some stuff.
haha the driver side rotor was rusted on...pb took care of that too. I dont like how rusted my brembos got...
Old 09-03-2007, 07:55 PM   #12 (permalink)
The Greatest
^You don't ever want to get PB/WD-40 on your rotors. Make sure they are thoroughly clean.
Edit: Good to know you finally got it off though. I hate pounding on Rachets because they just bounce right back.
Old 09-03-2007, 08:05 PM   #13 (permalink)
nodrogkam's Avatar
i see...
well i clean all brake parts and what not before and after assembly, definately before the final drive.
Old 09-03-2007, 08:09 PM   #14 (permalink)
The Greatest
Don't ask me why, because i don't remember. I was at a guy's house, and he told me that when he was teaching me how to do my brakes. I think that's why he never used said product when we were tryingt o get my brake line off.
I think it might be because the oil makes it hard for you to remove the rotor, or maybe it makes the pad hard to catch on the rotor. But you want that rotor really really clean.
Old 09-03-2007, 08:13 PM   #15 (permalink)
nodrogkam's Avatar
lol well of course u dont want oil on ur brakes...lol! ever tried walking over some oil slick? :-p
Bleh...are anyone's rotors this rusty?
Adjusting E Brake ForTech 2nd Generation (2005+) 15 09-23-2007 12:36 PM
Rear Drum Brakes Syndacate Tercel, Paseo, Starlet, and Sera Forum 13 08-20-2007 02:56 PM
07 V6 brakes? lalojamesliz 5th & 6th Generation (2002-2006 & 2007-2011) 31 06-18-2007 08:56 AM
Drum Brake removal (How?) SolaraTRD Camry & Solara Lounge 5 07-21-2005 06:19 AM
Celica/MR2/Camry 5sfe 6 bolt or 8 bolt crank??? Talisman General Discussion 2 06-12-2004 01:48 PM
