Transmission Pan Drain / Differential Drain - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-03-2007, 05:34 PM   #1 (permalink)
4th Generation Transmission Pan Drain / Differential Drain
I just finshed removing my transmission pan. ... Just draining the ATF fluid ... not flushing.
Even with just 44k mi. there was a lot of grey iron colored dust in the bottom of the pan. I don't see how any sort of transmission flush could get all of that out of the pan. ... Had to wash it several times with gas. The strainer didn't show anything at all .... rinsed it out anyway.
The differential was easy to drain ....'98 5s-fe auto means separate differential fluid. Wasn't prepared for getting the new ATF fluid back in the narrow space where the fill hole is located. Got most of it back in, but I'm going to find a piece of copper tubing and bend some curves, somehow add a funnel on top of it.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 09-03-2007, 09:02 PM   #2 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
Could try the clear plastic tubing. Comes in numerous sizes and flexs well plus you can force it onto the funnel for a tight fit.
Dave's is offline   Reply With Quote
Old 09-04-2007, 01:21 AM   #3 (permalink)
I tried a funnel and tube assembly that I got from the auto parts store. It was too short .... maybe need 2 feet of length, and it tended to kink ... and completely stop the flow of the ATF from the funnel. There is almost a 90 degree bend where the tube enters the fill hole.
I might try some different plastic tube from the hardware store and see if that does any better. Plastic tube would be easier to attach to a funnel.
Old 09-04-2007, 12:04 PM   #4 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
the auto stores sell a cheap manual pump that has rubber hose attachments for pumping fluids into weird places.
Old 09-04-2007, 12:10 PM   #5 (permalink)
..... might take a look.
Old 09-04-2007, 12:50 PM   #6 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
X2
Get a hand siphon pump, they usually come with more than enough of the clear flexible tubing that can be removed and you might be able to stick a funnel on one end. That's what I did the last time I changed my diff fluid.
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 09-04-2007, 09:08 PM   #7 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
To fill the differential, I got a piece of 3/8" ID PVC/Vinyl hose from the hardware store, ran that to the top of the engine bay, and mated it to a funnel using a barb fitting. I think I used 4 or 5 ft.
2007 Camry 2.4L 5M
Old 09-05-2007, 07:13 AM   #8 (permalink)
ghettosled's Avatar
this is the type im referring to...
submerge the short tube into the fluid you are pumping, and insert the long tube into the differential. this will allow you to pump vertically and closely monitor when the differential is full.
Old 09-05-2007, 08:22 AM   #9 (permalink)
HELP: Serious Transmission Problems arcasmachineracing Camry & Solara Lounge 23 06-22-2008 11:53 PM
transmission drain plug quickhands 2nd Generation (2000-2004) 2 07-02-2007 09:43 AM
'95 Celica GT Import Transmission Drain DJC Celica Forum 9 03-11-2004 05:02 AM
Transmission Pan Gasket or Sealant? l1n1234 Camry & Solara Lounge 2 02-19-2004 11:33 AM
