Just Cracked My Side Mirror. Help Plz! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-04-2007, 03:23 AM   #1 (permalink)
99 Camry LE
View Gachinto's Photo Gallery
Unhappy Just Cracked My Side Mirror. Help Plz!
Just made a stupid mistake, broke my left side mirror while getting out of my garage. Too tired.
It only has a crack under it, the mirrow and other parts isn't a problem. I should nevertheless try and fix it, good thing I probably dun need to buy another one. How do I take out the entire mirrow so I can glue it?
Thank you guys.
Gachinto is offline   Reply With Quote
Old 09-04-2007, 07:31 AM   #2 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
I don't know about the gen 4, but the mirror itself can pop out on a gen 3, I had to pry from the bottom up, the parts that snap in were on the bottom then all I had to do was pry outward and the two pieces on top were kinda hooked into the housing.
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 09-04-2007, 01:18 PM   #3 (permalink)
TLS FANatic's Avatar
View TLS FANatic's Photo Gallery
from the inside, pop out the plastic cover and you'll see 3 (i think) bolts. Remove the bolts, unplug the power window wire and take out the mirror.
TLS FANatic is offline   Reply With Quote
Old 09-04-2007, 06:13 PM   #4 (permalink)
4th Gen Camry Owner
View kpszar's Photo Gallery
Thats right. Takee the cover off in the inside of your car, then there should be three screws but remove the cable(if your car has power windows). Then unscrew and have fun!
kpszar is offline   Reply With Quote
Old 09-06-2007, 01:10 AM   #5 (permalink)
99 Camry LE
Is that where my 2 tweeter speakers are? Dun I have to take the entire inner door apart inorder to find the screws for the side mirror?
Old 09-06-2007, 02:26 PM   #6 (permalink)
yea, you dont need to take the entire door panel off tho, just the plastic cover
Aftermarket alarm installation ?... Crowleys Camry Audio, Video, and Security - Tech 5 03-17-2005 06:10 AM
1985-89 Side Skirt Seal KIT#12311970 kbox MR2 Forum 5 11-27-2002 11:28 AM
