Radiator Leaking!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-05-2007, 09:04 PM   #1 (permalink)
w00! I drive a Camry
View CamBOT's Photo Gallery
3rd Generation Radiator Leaking!!!
I was driving my car and noticed smoke coming from under the hood. So I got home and looked under the hood.
There is a tiny hole on my radiator where the coolant is spewing out. The leak is very minor and slow.
Is there anyway to patch the hole up? I would usually replace the radiator, but the radiator is only about 6 months old. Also the leak is very minor, almost sweating out.
Any help would be appriciated.
Thanks.
CamBOT
CamBOT is offline   Reply With Quote
Old 09-05-2007, 09:07 PM   #2 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
it can be patched and it might cost 60$.
Radiator shop
skewe is offline   Reply With Quote
Old 09-05-2007, 09:10 PM   #3 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
If the leak is in the fins, not the tanks, and you have a copper core you can usually solder it. If it is aluminum core, I don't know how to fix it. If it is in the plastic tanks (upper or lower) you have to replace it (don't bother with that cheap crap that plugs it, it never holds). I would recomend replacing it no matter what. You can find one cheap on ebay ($70-$80). Since you said it is only 6 months old, is it still under warrenty/ can they replace it for you?
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 09-05-2007, 09:11 PM   #4 (permalink)
The leak is at the very top of the radiator and easy to get to.
Can i use JB weld?
CamBOT
Old 09-05-2007, 09:12 PM   #5 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
If it is under a warranty...dont do ANYTHING to it without first contacting the manufacturer.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 09-05-2007, 09:18 PM   #6 (permalink)
I cheaped out got a no-name radiator with only a 6 month warranty. Its been 7.5 months...talk about ripoffs!
CamBOT
Old 09-05-2007, 09:18 PM   #7 (permalink)
'95 Camry 5S-FE
JB weld might hold it temporarily, but don't count on it holding forever. You said it is at the very top? If it is the top plastic part (upper radiator tank) the rad is shot. That plastic can not be reliably patched.
Old 09-05-2007, 09:21 PM   #8 (permalink)
'95 Camry 5S-FE
http://cgi.ebay.com/ebaymotors/Toyot...spagenameZWDVW
I have this one. Works great, and has a lifetime warrenty (both defects AND wear and tear).
only $74 shipped, good people!
Oh, don't bid on ebay, rather call them and use your credit card, you will have it the next day, no extra charge.
Old 09-05-2007, 09:34 PM   #9 (permalink)
Its not the platic its a small crack in metal. I'll try JB weld..if not i'll get a new rad.
Its just that i'm strapped for cash at the moment.
CamBOT
Old 09-05-2007, 09:37 PM   #10 (permalink)
'95 Camry 5S-FE
If you have a copper core rad (the fins are made of copper, usually painted black) you can solder it, and that will hold.
Old 09-05-2007, 09:43 PM   #11 (permalink)
Thanks for your help.
I'll do that tomoro when i get home from school
CamBOT
Old 09-05-2007, 10:04 PM   #12 (permalink)
'95 Camry 5S-FE
when you solder it, use a propane torch, not a soldering iron, and use acid-core solder, not rosin-core solder(electrical solder).
Old 09-05-2007, 10:33 PM   #13 (permalink)
Oh boy, its worse than I thought.
Its not a crack in the metal.
The leak is from the very top part of the radiator. Its a type of very hard plastic?
Is that right?
I guess i'll need a new rad.
CamBOT
Old 09-05-2007, 11:24 PM   #14 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
Dude, just get another radiator, gaaaawd!!
CLICKY HERE
RichieRichJP is offline   Reply With Quote
Old 09-05-2007, 11:27 PM   #15 (permalink)
'95 Camry 5S-FE
Yea, you need a new rad. I suggest trying radiator doctor on ebay
They have lifetime warrentys and have a rads for $70-$80 shipped. I have one and love it.
Don't buy it through ebay, rather call them at 1-800-717-8557, mention the ebay item #, and buy it over the phone and you will have it next day.
