Replacement interval for TB on the V6 is 90k miles, as I recall.
There is a small orifice on the water pump, which can be used to tell if any coolant is leaking around the pump shaft .... indicating failure. You should see a mineral or precipitate buildup if there is an immediate problem.
This is a picture of my old defective water pump ... only 44k miles, and you can see a little of the mineral buildup at the leakage hole. .... You only see the edge of the pump when it is installed.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
