Ignition Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-06-2007, 06:38 PM   #1 (permalink)
View Pkim87's Photo Gallery
Ignition Problem
Hey guys I have a 1997 Le (4cyl) auto and I am having problems turning the key to start the car. When I try to start the car the key gets stuck and won't turn and I have to keep messing with it until the key goes in and finally turns to start the engine. I have no idea what the problem is I tried using different keys but the problem keeps arising so I ruled out my keys being the problem. TIA
Pkim87 is offline   Reply With Quote
Old 09-06-2007, 06:44 PM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
It may be the key or the lock cylinder. If the key you're using has been cut from an old key then it too will be bad. I would start by taking the car to a dealer and they will cut a brand new key from the VIN. Take ID and the registration so they can verify you are the owner.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 09-06-2007, 09:27 PM   #3 (permalink)
So if i use the keys that came with the car or order new keys from dealer it would solve the problem? I am not sure if i am using copied keys or original. Probably copied because there isnt a toyota logo on the black part.
Old 09-06-2007, 10:41 PM   #4 (permalink)
View toyomoho's Photo Gallery
Try the original OEM a key or a new key made from the VIN and see if this improves things. If not the issue may be the cylinder, they can wear out. Have you tried moving the steering wheel when attempting to start the car?
Old 09-06-2007, 11:06 PM   #5 (permalink)
the steering wheel is not locked and yes i have tried moving it around when putting in my key. If it is the cylinder head how much does that cost? And for new keys how much does the dealer charge.
Ignition problem ....Help!! mab1958 89-95 Toyota Pickup/Hilux 10 10-21-2007 06:07 PM
Camry Ignition Lock problem Nayak Camry & Solara Lounge 4 03-26-2006 12:30 PM
Help! plz ignition problem luis9519749 Celica Forum 2 01-09-2006 04:28 PM
