front abs engages when coming to stop - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-08-2007, 03:09 AM   #1 (permalink)
View hmthomas's Photo Gallery
Hello, I just had new cv axles installed on my '93 Camry. The first set did not have abs teeth and so I got the abs light and read the codes stating circuit interruption on both right and left. I had the correct cv half shafts installed. Since the install, whenever I come to a stop, just prior to stopping the brakes grab and release (abs engaged?). I hear/feel the pulses and the car completes the stop. If I brake ever so smoothly I can avoid the interruption. There are no codes or lights. Any ideas?
hmthomas is offline   Reply With Quote
Old 09-08-2007, 07:32 AM   #2 (permalink)
Gameroom cash: $401950
View Stillrunning's Photo Gallery
Sounds like a wheel speed sensor problem.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 185K
Stillrunning is offline   Reply With Quote
Old 09-08-2007, 09:17 AM   #3 (permalink)
Thanks for the input...without codes, how do I tell which sensor?
Old 09-08-2007, 10:39 AM   #4 (permalink)
View hoiskii's Photo Gallery
If this were not cv axles than I'd say it's time to change struts. I had the same probelem, every time abs engaged if I push prabes a bit harder or the road surface is wet or bumpy, before changing the struts.
hoiskii is offline   Reply With Quote
Old 09-08-2007, 01:03 PM   #5 (permalink)
I think hoiskii has a valid solution. Certainly if the wheels are not able to stay in contact with the ground then they will not turn at the same rate and will trigger the ABS.
hmthomas, does this happen rough road or smooth road, slow or fast? I guess the other possibility since this just started after the axle install is that maybe one axle has incorrect # of splines. The sensor then would pick up what it considers different wheel speeds. I don't know if it's possible to mismatch axles this way??
Old 09-08-2007, 01:18 PM   #6 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
Ditto. Replaced struts and it's gone, and plus you have a MUCH improved ride quality, because the struts are brand-spanking new.
BlueFusion6851 is offline   Reply With Quote
Old 09-08-2007, 01:20 PM   #7 (permalink)
it happens on smooth roads coming to a stop (maybe when it's going 2-7 mph) at a normal (non panic or hard stop) rate of braking. thanks for any input
Old 09-08-2007, 05:24 PM   #8 (permalink)
I found this on a Volvo with somewhat of the same problem you have.
"ABS Pulses at Low Speeds
[Problem]he ABS acts up when I'm driving at low speeds and applying hardly any pressure to the brake pedal of my 1990 740 GLE. The ABS lifts the brake pedal in the same way as if it was locking up.
[Answer]You should remove and clean the front wheel speed sensors. To do this turn wheel full lock to one side and then remove the sensor from wheel that is turned out by undoing a 5 mm Allen screw you will see adjacent to arm where tie rod for steering attaches. Then turn wheel to full lock the other way and do the same on other side. Also unplug and then reconnect the sensor connectors that are in the engine compartment near top of struts. This should effectively clean the connections. This can also cause low speed inappropriate ABS activation."
So you may just have dirty sensors. You may also have a damaged tooth on the spline.
If you are capable I would pull the front sensors and check them. When you remove them you may be able to see down inside to the teeth on the axle. If you turn the axle you may be able inspect each tooth for dirt/damage.
Old 09-08-2007, 05:59 PM   #9 (permalink)
This sounds promising...I'll give it a shot tomorrow...thanks much!!
Old 09-09-2007, 05:07 PM   #10 (permalink)
Update....
Well I removed the sensors and noticed that one had a couple of gouges on the sensor surface (maybe from when the cv axel bumped it). The other had some shavings from where one part must have come in contact with the hub. Cleaned them both and put them back. Problem still there. Also, last night while driving in Seattle, the ABS light came on and so I thought, finally, I'll get a code! When I parked it and went to check the code, there was none and the ABS light now is off again.
Old 09-12-2007, 04:28 AM   #11 (permalink)
I work on euros.
View 96CamrySport's Photo Gallery
find the electrical connector for the gouged wheel speed sensor, it should be of the two pin variety. Jack up that wheel off the ground, trans in neutral and e-brake set, plug a dmm into the sensor (don't damage the pins) and set dmm to a/c low voltage. Spin the wheel, and you should get a signal at around 2-4 miles per hour. repeat for other side and see if signals are reasonably similar. That's about the easiest way for the diy guy to check his wheel speed sensors. If a sensor is losing signal early, the abs module would see it as a locked wheel. did you do the work yourself or did a shop do it?
1996 Camry Sport (that's a DX Coupe with decals) with 186k
european cars are just like japanese cars, just heavier and more expensive.
7 ASE's.
96CamrySport is offline   Reply With Quote
Old 10-17-2007, 07:18 AM   #12 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
Bumpski to see if the OP resolved this issue.
DFBonnett is offline   Reply With Quote
Old 10-17-2007, 11:53 AM   #13 (permalink)
View Life2's Photo Gallery
They messed up when they put your brakes back together. I had made almost the exact same thread two weeks ago haha.
96 camry v6 xle
91 mr2 n/a
Life2 is offline   Reply With Quote
Old 10-17-2007, 12:14 PM   #14 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
same thing happened to me when i got my new brakes this summer .... unfortunately another piece was broken in the rear ABS, so Beaman Toyota of Nashville got a good $500 out of us
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 10-17-2007, 04:54 PM   #15 (permalink)
'93 LE Wagon, V6
Linkage please?
Clunk when coming to a stop? Nsurenu Sequoia Forum 4 09-01-2007 06:25 PM
ABS wheel speed sensor, front DFBonnett 3rd & 4th Generation (1992–1996 & 1997–2001) 2 01-20-2007 12:41 PM
Stalling when coming to a stop Smiff 24 Camry & Solara Lounge 7 10-31-2005 09:51 PM
Drift Setting help for GT3 I hate Toyota Corp :( Off Topic 3 11-10-2003 11:36 PM
