Help ! 98 Camry Temperature Gauge Issues - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-08-2007, 11:09 PM   #1 (permalink)
View cato47's Photo Gallery
Just bought a 98 Camry 4cyl today with 111K miles. Drove 350 miles to get it. On the way home the temp gauge seemed to be all over the place. For the first 3 hours it ran between cold and the half way mark on the gauge. As it got into the evening it started moving closer to the cold mark, and at times was maybe 1/8" above the cold mark. When I stopped at a gas station I left it running and the gauge came up not quite a 1/4 inch below the half way point. My 92, 94 and 99 Camrys all ran with the pointer dead on in the middle of the gauge. Can someone tell me whats going on?
Thanks,
Rick
cato47 is offline   Reply With Quote
Old 09-08-2007, 11:15 PM   #2 (permalink)
The Greatest
View CamNub's Photo Gallery
What's with the large font?
Sounds like your thermostat is stuck open. It's not closing and coolant is rushing through the system at all times, giving you a cold engine.
CamNub is offline   Reply With Quote
Old 09-08-2007, 11:21 PM   #3 (permalink)
CamNub
Sorry about the big font I didn't know it was going to be that big. Could the cooling fans be running all the time?
Old 09-08-2007, 11:22 PM   #4 (permalink)
Two possibilities:
Your engine has a coolant related malfunction.
Your temperature gauge sender is defective or has a connection problem ...
Suggest you first locate the dash gauge temp sensor and insure that the connectors are clean and making good electrical contact. It has a single wire .... yellow with green stripe. ...
Does engine show any obvious problems .... other than unusual gauge indication?
If not, might just be defective dash gauge sensor ...
"thermostat is stuck open"
thermostats stop working sometimes .... easy to replace.
I get 20 or 21 mpg in the city ... maybe close to 30 hwy.
How is your mpg doing?
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 09-08-2007, 11:26 PM   #5 (permalink)
The Greatest
It could be, but it sounds a lot like the t-stat is stuck open.
I had the same problem on my car. I was pretty normal (slightly cold) locally, but once I hit the highway, my temp would drop to the bottom. The car runs a lot better now that I changed out the t-stat.
Imo, if your ECT (Electrontronic Coolant Temp) sensor was bad, you'd have fluctuating temperatures, and the gauge would go wild.
BTW: Please edit your post and turn down the size (or remove it).
Edit: Change out the t-stat. It's cheap and easy to fix. Don't jump to the expensive conclusions (fan) right away.
Old 09-08-2007, 11:29 PM   #6 (permalink)
Temp Gauge Issues
dc_98_cam
The engine ran as smooth asd a sewing machine without any issue for the entire 350 miles. Where is the sending unit located on the engine?
Thanks
Old 09-08-2007, 11:32 PM   #7 (permalink)
The Greatest
^It should be located right under the t-stat or near it.
Old 09-08-2007, 11:34 PM   #8 (permalink)
dc_98_cam
Thanks
Right in the front of the engine block .... towards the right end of the block ... yellow wire with green stripe.
See link here for gen 4 ... download electrical wiring diagram .... p. 28 .... part W3.:
http://www.camrymanuals.com/index.ph...=107&topicid=0
.... link given here is sometimes not working .... download GetRight program... activate Drag and Drop Button ... then drag and drop desired link onto button. ... no problems.
Old 09-08-2007, 11:44 PM   #9 (permalink)
Temp Gauge Issues
dc_98_cam
CamNub
Thanks brothers for the tips. It's almost 1am here. Tomorrow I will check the wire to the sending unit. If that looks OK I'll go for the thermostat. Will an after market Advance Auto Parts stat be OK or should I wait till monday and get an OEM stat from Toyota? In any case, what degree stat should I put in it if I go with my local auto parts store?
Thanks again!!!
Old 09-09-2007, 12:27 AM   #10 (permalink)
Temp Gauge Issues 98 Camry
Is an after market stat OK to use or should I get Toyota OEM? What about antifreeze? I've heard that you should ohnly use Toyota's anti freeze. What say you about that?
I got 33MPG hiway on my 99 Camry.
Old 09-09-2007, 12:58 AM   #11 (permalink)
View hoiskii's Photo Gallery
Is an after market stat OK to use or should I get Toyota OEM? If an after market stat is ok,what temp should I get?What about antifreeze? I've heard that you should only use Toyota's anti freeze. What say you about that?
The temperature gauge - any one should work... I take the next part to the cheapest one as a rule of thumb.
Temperature - you can look at the manual at camrymanuals.com.
Toyota antifreeze only - it sounds b.s. to me.
hoiskii is offline   Reply With Quote
Old 09-09-2007, 05:26 AM   #12 (permalink)
I used OEM thermostat and gasket .... no particular reason ... possibly the idea of better or longer reliability. .... Name brand replacement ought to work though.
The only issue with thermostat installation is sometimes an air bubble will form in the vicinity of the thermostat housing. The OEM thermostat has a small 'wiggle valve', which when installed at 12 o'clock orientation will allow air pocket to purge to radiator. ... If you have thermostat with no wiggle valve, it is suggested to drill a small hole, maybe 1/8" dia. at the 12 o'clock position of the outer thermostat flange. ... Others have commented about difficulty of getting all air out of system after refilling with coolant. Should be no problem with wiggle valve, or small hole .... properly installed.
Choice of coolant .... Toyota OEM Red. Probably avoid green. I used a NAPA product, said to be compatible with any type of coolant. ... kind of clear colored. ... Mix as directed with distilled water to avoid mineral precipitate buildup.
... Don't recall exact thermostat temperature .... seems like 180F or something close to that.
Old 09-09-2007, 10:47 AM   #13 (permalink)
Toyota Technician
-=]KaiN[=-'s Avatar
View -=]KaiN[=-'s Photo Gallery
toyota does recommend only the red long life antifreeze, because the amount of silicates contained in the green stuff can create a by product toyota doesnt really like. If your going to use the green stuff just change it more often. As far as tempurature the trd thermostats for the 1mz-fe v6 are 160 degrees, but on some 00 and later camrys the ecu monitors coolant temp for thermostat codes you may want to stick with the oem tempurature if you have a camry later than 99.
-=]KaiN[=- is offline   Reply With Quote
Old 09-09-2007, 11:16 AM   #14 (permalink)
Gameroom cash: $303055
I would use a Toyota OEM thermostat. There is only a few dollars difference vs. aftermarket and the OEM one has a little bleed hole that some of the aftermarket ones do not have. You don't change the thermostat that often so the extra few dollars it will cost is worth it to me. I have always used aftermarket antifreeze in all my Toyotas with no problems. YMMV.
Mike
Old 09-12-2007, 03:20 AM   #15 (permalink)
I work on euros.
View 96CamrySport's Photo Gallery
thermostat opens at 190f and fans should kick on at 230f. whatever coolant you use, use only that coolant in the system. green should be ok, toyota will probably make the car live a slight bit longer, but who knows? Just make sure you put the stat in the right way, or it'll overheat. big pellet side with the spring goes to the engine side.
1996 Camry Sport (that's a DX Coupe with decals) with 186k
european cars are just like japanese cars, just heavier and more expensive.
7 ASE's.
96CamrySport is offline   Reply With Quote
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 01:04 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
98 camry 5FSE to 3SGTE S13/R32 3rd & 4th Generation (1992–1996 & 1997–2001) 3 11-09-2004 07:56 PM
