Crank Shaft Bolt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-09-2007, 08:08 PM   #1 (permalink)
R/C Junkie
View Smiff 24's Photo Gallery
3rd Generation Crank Shaft Bolt
Hello all,
is the crankshaft pulley bolt a normal right hand, or
is it a left hand bolt ? I have a 94 4cyl. camry.
Ive read a lot about gettin it loose but havent seen
anything about if its right or left hand. Thanks,
94 camry le 4 cyl.
Smiff 24 is offline   Reply With Quote
Old 09-09-2007, 08:22 PM   #2 (permalink)
View hoiskii's Photo Gallery
Originally Posted by Smiff 24
Hello all,
It's a normal bolt that you can loose by turning counterclockwise. (at least on 99 I4)
hoiskii is offline   Reply With Quote
Old 09-09-2007, 08:47 PM   #3 (permalink)
R/C Junkie
Thanks hoiskii, gonna work on it tomorrow.
94 camry le 4 cyl.
Old 09-10-2007, 07:07 AM   #4 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
normal for the gen 3 models as well.
Old 09-11-2007, 05:36 PM   #5 (permalink)
R/C Junkie
I used an electric impact to remove the bolt, my air impact wouldnt budge it!
Put a new pulley on, engine is runnin smoothe again, 240,000 mi. and still goin!
THANKS for the info & help !
94 camry le 4 cyl.
Changing V6 Timing Belt Pics and the $270 Coil Connector marc780 5th & 6th Generation (2002-2006 & 2007-2011) 81 04-09-2012 07:26 AM
Crank Bolt rwschneider1 Celica Forum 5 12-12-2006 12:51 PM
Drive Shaft Bolt briangk_77 Archived Corolla threads 8 09-07-2005 02:25 AM
Matrix Drive Shaft Bolt briangk_77 1st Generation (2003-2008) 2 05-02-2005 08:32 AM
Problem with crank shaft & pulley - corolla 97 KaV Archived Corolla threads 1 05-21-2004 02:02 AM
