EGR Modulator filter removal - How??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-10-2007, 11:18 AM   #1 (permalink)
View bnb1023's Photo Gallery
My 96 4 cylinder is stalling, so from prior threads I'm going to use the sea foam and clean the throttle body. But, in the manuals provided in this forum, it also says to clean the filter in the EGR vacume Modulator, and even shows a drawing of it, But, how do you get it apart? Does it screw or must you pry it off? I do not want to screw it up.
Also, can you clean the EGR valve without removing it, and if so, how? Thanks.
'98 Camry LE
bnb1023 is offline   Reply With Quote
Old 09-10-2007, 11:26 AM   #2 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
fro the modulator you should be able to pop the top off of the modulator and the filter should be right there
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 09-11-2007, 06:39 AM   #3 (permalink)
cleaning egr parts
That doen't tell me much, Creeps. HOW does it pop off/ Mine does not want to come off easily. Where do you pry it? Can I squirt the sea foam into the outlets of the egr? Will it do any good?
'98 Camry LE
Old 09-11-2007, 10:05 AM   #4 (permalink)
Creeps228's Avatar
Umm, its should just pop off, pull it hard enough and it should come right off, and i dont think squirting seafoam in there would be a good idea
MR2: 7A-GE
Old 09-11-2007, 12:23 PM   #5 (permalink)
OK,....here goes... GOT I!
Thanks Creep!
'98 Camry LE
Old 09-11-2007, 02:21 PM   #6 (permalink)
Creeps228's Avatar
Np
MR2: 7A-GE
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
egr removal reachkev 89-95 Toyota Pickup/Hilux 0 07-01-2007 02:25 PM
EGR System Testing and removal problems camrii Camry & Solara Lounge 2 07-05-2006 01:35 PM
EGR Valve Removal Arbee2 4Runner Lounge 0 12-26-2005 03:27 PM
Benefits Of EGR removal numbone MR2 Forum 10 09-08-2005 05:44 AM
