Brake lights come on randomly - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-10-2007, 04:45 PM   #1 (permalink)
View xtinxkanx's Photo Gallery
Hello,
Have a little problem here. On a regular drive and from time to time, the hand brake light on my dashboard turns on and then if I stop completely, it turns off. Not quite sure what could be causing the problems. I did try to pull the hand brake up and releasing it while I am still in motion; However that did not do the trick.
I believe it turns on more frequently when I do make a turn.
And I did notice the light go off once when my driver side rear wheel ran over a pot hole.
Any ideas?
I have a 2000 Camry LE
xtinxkanx is offline   Reply With Quote
Old 09-10-2007, 04:51 PM   #2 (permalink)
View vdop69's Photo Gallery
make sure your brake fluid is at the fill level.
vdop69 is offline   Reply With Quote
Old 09-10-2007, 04:52 PM   #3 (permalink)
At the current moment, it is inbetween low and full.
Old 09-10-2007, 05:00 PM   #4 (permalink)
I would try filling the fluid to full and see if the light stays off.
Old 09-10-2007, 05:01 PM   #5 (permalink)
Will do, i will update after.
Old 09-12-2007, 04:42 PM   #6 (permalink)
I did do that, and the light did go off.
However, this worries me. Usually brakefluid does not need to be filled.
My brake pads do look like they have a good amount left on them for both drum and front.
Could this be caused by a warpped drum?
Old 09-12-2007, 05:12 PM   #7 (permalink)
TACO FTW
Location: Norton Shores, MI / Houghton, Michigan (MTU) FTMFW
View 92_Gen3_5SFE_LE's Photo Gallery
Toyotas are notourious for having the brake warning light come on from not having topped off brake fluid. the sensor is really sensative.
92_Gen3_5SFE_LE is offline   Reply With Quote
Old 09-12-2007, 05:14 PM   #8 (permalink)
then should i be worried on if my brakes are worn out?
I mean I did look at them and both pads and drum shoes looked fairly decent.
Old 09-12-2007, 05:23 PM   #9 (permalink)
If the brake warning light comes on again, you should be on the lookout for some sort of leak. ... Maybe remove wheels .... examine calipers, drums. Brake fluid has to go someplace.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 09-12-2007, 05:26 PM   #10 (permalink)
I am going to do another check on the drums tonight. I want to see if they are warpped.
Do you know what the usual thickness the shoes are before they go bad like the minimum
I do have a caliper so i am going to measure it but i dont know the thickenss.
Old 09-12-2007, 05:55 PM   #11 (permalink)
View toyomoho's Photo Gallery
The minimum thickness for both pads and shoes on a Gen_3 is 0.039 inch don’t know for a Gen_4.
Warped drums or rotors should not cause this. Are you sure this generation has electronic brake wear indicators?
The issues seem to be if the brake fluid is leaking somewhere and the brake fluid level sensor is over sensitive.
Old 09-12-2007, 06:06 PM   #12 (permalink)
I agree with the possibiliy of a leak. Any pointers on where to look first?
Old 09-12-2007, 06:16 PM   #13 (permalink)
I dunno...I had this problem before and just added fluid and havent had a problem since, and that was about a year or more ago.
Old 09-12-2007, 06:17 PM   #14 (permalink)
so no leaks?
Old 09-12-2007, 06:19 PM   #15 (permalink)
No, I didnt have any leaks. But your situation might be different. If I were you I would just wait and see if the level of fluid goes down after a couple weeks.
Bed Lights Install DIY Fluxaholic 2nd Generation (2005+) 12 07-28-2009 09:56 PM
Charge AND Brake Lights on-HELP! Longstreet Pre-88 Toyota Pickup/Hilux 14 08-13-2006 11:40 PM
Brake lights staying on.... RA24_4_Me Archived Corolla threads 6 08-07-2006 11:54 AM
brake lights. hellomota Camry & Solara Lounge 4 07-22-2006 11:25 PM
All brake lights don't come on... oibone781 Camry & Solara Lounge 20 02-09-2004 11:20 AM
