Modifications for those who are new to camry tuning - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-11-2007, 08:55 PM   #1 (permalink)
Import Tuning
camry man68's Avatar
View camry man68's Photo Gallery
This is just a quick list i came up with i'll add more later. All these items are for a 97-01 5sfecamry and some of these parts will work on a 92-96 4cyl.
Performance
injen cold air intake-http://www.car-stuff.com/store/?N=17...272+11784+5565
injen cold air intake-http://www.cardomain.com/item/INJIS2030P
injen is intake for v6 camrys-http://www.sportcompactonly.com/Shor...-87_p-5375.htm
Remus Exhaust-http://www.cardomain.com/item/REMM254860113
Greddy Evo2 Exhaust-http://www.greddy.com/products/displ...&SubCategory=2
Unorthodox Racing Underdrive S Pulley-http://www.unorthodoxracing.com
Radiators-http://www.autopartswarehouse.com/pr..._name=radiator
JET Chips ECM Recalibration Kit-http://www.autopartswarehouse.com/pr...alibration_kit
Bosal Headers-http://www..com
Cometic Head Gaskets-http://www.sportcompactonly.com/Toyo...27_vy-1999.htm
AEM Fuel Pressure Regulator-http://www.sportcompactonly.com/Toyo...27_vy-1999.htm
Skunk2 Throttle Body-http://www.sportcompactonly.com/Thro...48_p-51320.htm
NGK Spark Plug Wires-http://www.sportcompactonly.com/Spar...120_p-4322.htm
Magnecor Spark Plug Wires-http://www.sportcompactonly.com/Spar...120_p-9389.htm
NGK Iridium Spark Plugs-http://www.sportcompactonly.com/Spar...45_p-23842.htm
Westar Engine Mounts-http://www2.partstrain.com/store/pro...e=engine_mount
Top Line Camshafts-http://www.importperformanceparts.net
Suspension
Tein Super Street Damper Coilovers-http://www.cardomain.com/item/TEIDSL16KUSS2?vq_id=none
Ground Control Coilovers-http://www.cardomain.com/item/GRO805301?vq_id=none
Eibach Pro Kit Springs-http://www.cardomain.com/item/EIB8249140?vq_id=none
Tokico Hp Series Struts-http://www.cardomain.com/item/TOKHB3184?vq_id=none
K-Sport Pro Control Coilovers-http://www.ksportusa.com/products/kontrolpro.html
KYB GR-2 Struts-http://www.tirerack.com/suspension/s...711&perfCode=P
H&R Sport Springs Set-http://www.tirerack.com/suspension/suspension.jsp?&make=H%26R&model=Sport+Spring+Set& group=Sport+Spring+Set&autoMake=Toyota&autoModel=C amry+CE&autoYear=1999&autoModClar=&partNum=29780&p erfCode=S
Netami Strut Bar-http://www.cardomain.com/item/NET671031
TRD Lowering Springs-http://www.toyotaterritory.com/detail.aspx?ID=381
Arospeed Strut Bar 92-96 Camry-http://www.slickcar.com/productdetai...ProductID=1182
Whiteline Sway Bar-http://www.whiteline.com.au/default....=/swaybars.htm
Brakes
PowerSlot slotted rotors-http://www.cardomain.com/item/PWS718PSL?vq_id=none
PowerSlot cross drilled rotors-http://www.cardomain.com/item/PSPJBR712L?vq_id=none
Brembo Sport Cross Drilled Rotors-http://www.tirerack.com/brakes/brake...ar=&perfCode=S
Brembo Sport Slotted Rotors-http://www.tirerack.com/brakes/brake...ar=&perfCode=S
Rotora Big Brake System Front-http://www.autoaccessorystore.com/ho...detail&id=2868
Exterior
Evo4 Body Kit-http://www.bodykits.org/cart/view_pr...hp?ItemID=3239
R34 Body Kit-http://www.bodykits.org/cart/view_pr...hp?ItemID=3242
Spyder Body Kit-http://www.bodykits.org/cart/view_pr...hp?ItemID=3244
Evo2 Body Kit-http://www.sportcompactonly.com/Body...201_p-4198.htm
Halo Projector Headlights-http://www.xtralights.com/index.asp?...ROD&ProdID=390
Headlight & Taillight tint blue, yellow, smoke, red-http://www.decalfx.com
Keystone Side Mirror-http://www.sportcompactonly.com/Hood...35_p-15867.htm
Extreme Dimensions Grill Mesh-http://www.sportcompactonly.com/Exte...26_p-58206.htm
L.E.D. and Neon Lighting-http://www.urban-neon-car-lights.com/
VIS Carbon Fiber Hoods, OEM and Invader-http://www.autoaccessorystore.com/ho...detail&id=2637
VIS Carbon Fiber Trunk-http://www.autoaccessorystore.com/ho...detail&id=2641
Mimo USA Carbon Fiber Hood-http://www.autoaccessorystore.com/ho...izard=&s=&mid=
Polyurethane Paintable Eyelids-http://www.autoaccessorystore.com/ho...=detail&id=669
Carbon Fiber Eyelids-http://www.autoaccessorystore.com/ho...=detail&id=643
Xenon Mods a site for bulbs, decals and leds-http://www.xenonmods.com
Camry Clear Corners, for all years-http://www.slickcar.com/accessories/...ner_lenses.asp
Razzi Body Kit-http://www.razzi.com/product.php?mak...roduct_id=1201
Interior
Autometer Dual Gauge Pod-http://www.sportcompactonly.com/Gaug...19_p-22195.htm
26 Piece Dash Trim Kit Available in Carbon Fiber, Aluminum and Wood-http://www.autoaccessorystore.com/ho...izard=&s=&mid=
Modifications Tips and Info
Brake Fluid
Brake fluid is one of the most important brake upgrades and it is also the most overlooked. Heres a list of brake fluids and they're wet and dry boiling points.
Brake Fluid Dry Boiling Point Wet Boiling Point The higher the boiling point the better
DOT 3 Minimum(Stock) 401F 284F
DOT 4 Minimum(OE) 446F 311F
Castrol LMA DOT 3/4 446F 311F
DOT 5.1 Minimum(SuperStock) 500F 365F
Valvoline SynPower(what i use) 502F 343F
Motul 5.1 509F 365F
AP Racing 527F 302F
ATE TYP200 536F 392F
Ford Heavy Duty DOT 3 550F 290F
Castrol SRF 590F 518F
Motul RBF600 593F 420F
Brembo Racing LCF600 601F 399F
Neo Synthetic Super DOT 610 610F 421F
camry man68 is offline   Reply With Quote
Old 09-11-2007, 09:21 PM   #2 (permalink)
Lone star
blackhawk's Avatar
View blackhawk's Photo Gallery
nice post should be in the info section tho ied say
I HAVE NO IDEA HOW THIS WORKS
blackhawk is offline   Reply With Quote
Old 09-11-2007, 09:28 PM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
hmm thats good. nice job man.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 09-11-2007, 10:02 PM   #4 (permalink)
Experience>Post Count
View MIC0417's Photo Gallery
actually any of these will fit the 92-96 they are the same engine, possibly 20 mins of a little extra to fit or have vacuums otherwise fitment will occur
MIC0417 is offline   Reply With Quote
Old 09-11-2007, 10:32 PM   #5 (permalink)
slowamatic noob
a94autoCamry's Avatar
Gameroom cash: $149910
View a94autoCamry's Photo Gallery
you forgot kport coilovers ....
slow white - "no show and no go"
a94autoCamry is offline   Reply With Quote
Old 09-11-2007, 10:54 PM   #6 (permalink)
I HAS BOOST!!!
bigbird's Avatar
im lazy and dont want to search...do the V6 too
R.I.P.
Car Domain:
Old 09-11-2007, 11:36 PM   #7 (permalink)
Green Gang
View 213solider's Photo Gallery
THis is for the gen 4
Camry TRD
213solider is offline   Reply With Quote
Old 09-11-2007, 11:44 PM   #8 (permalink)
Lone star
blackhawk's Avatar
v6 do it do it me lazy too
Old 09-12-2007, 06:58 PM   #9 (permalink)
Import Tuning
im going to keep on updating the 5sfe list and im gonna start making a v6 list for all you who want it.
Old 09-12-2007, 07:48 PM   #10 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
you should put a Gen 4 logo in the thread title
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 09-12-2007, 07:54 PM   #11 (permalink)
Gen 3 & 4
All those parts are interchangable except possibly some of the supsension mods. I don't care if you say this is for Gen 4's it is both
Old 09-12-2007, 08:22 PM   #12 (permalink)
Import Tuning
Alright i changed it.
Old 09-12-2007, 10:52 PM   #13 (permalink)
It's pronounced "Nesquik"
View N35QU!K's Photo Gallery
This is a really good write up. Thanks to you, I finally know of a place to get Tokico Blue shocks for less than the $70/strut that I found
And I can tell you that ever since i rode in my uncle's fully loaded GS350, Ive wanted to get LEDs to light up my floor interior.
Click image for vehicle info (UPDATED 12.01.09)
N35QU!K is offline   Reply With Quote
Old 09-12-2007, 11:06 PM   #14 (permalink)
Import Tuning
*update* i just added carbon fiber exterior and interior pieces to the list.
Old 09-14-2007, 05:35 AM   #15 (permalink)
Import Tuning
i just added them
Camry V6 boosted tuning options tigris Camry & Solara Lounge 21 09-20-2007 01:17 AM
Complete 2007 Camry Crash Test Results.. PERFECT! islandboy57 5th & 6th Generation (2002-2006 & 2007-2011) 3 08-08-2006 06:43 AM
2003 TOYOTA CAMRY XLE vs. 2003 HONDA ACCORD [NEW].. Macreative 5th & 6th Generation (2002-2006 & 2007-2011) 7 09-15-2002 01:10 PM
TCI ANNOUNCES PRICES OF ALL-NEW 2002 CAMRY - F bondobondo 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-14-2001 12:48 PM
