Cheapest CAI DIY (gen3 or 4 V6) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-11-2007, 10:05 PM   #1 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
Talking Cheapest CAI DIY (gen3 or 4 V6)
::Im not a mechanic so if u screw somthing up, its YOUR fualt ::
ok so ive done 4 of these now on three gen3s and my gen4, so i figured i share the...well whatever u wanna call it.
now this example is on a gen4 V6 that already had a SIR so i had no need to relocate hoses. ill explain how to do this when it comes up. the I4 will work to but the process is a little different.
Cost: (most things can be bought at a hardware store)
3" dryer tubing- $8
heat insulation tape- $3 (used to wrap the ducting in the engine bay)
3" C clamp coupling(ineeded 2 since i had a SIR already)- $4
reusable cone filter - $25
Items needed to run hoses if needed:
2 brass hose nipples(3/4" i believe/hardware store)- about $3
hi-temp, silicone sealant - $3
Tools needed:
philips head and flat head screwdrivers (short ones will be needed for the gen3)
ratchet set w/extensions (ull mostly use 10mm)
wrenches woud be usefull but a skinny pair of pliers will do(for the fuse box)
ok so once uve organized ur parts and tools, either lift the front end and remove the drivers wheel(perfered) or turn the wheel all the way to the right.
1. disconnect battery and remove.
2. disconnect the intake tube from the airbox, pop the clips off the lid of the airbox and remove the lid and airfilter(leave intake tube in place, it holds most or all of the hoses)
3. there are 3 screws holding down the botton half of the airbox, unscrew these and remove the rest of the airbox(ull prolly need the extensions for this)
3. remove lid to main fuse box(gen3 has 2 separate boxes), then remove the screws holding the fuse box down.
4. at this point go underneith the car and remove the screws that hold on the black plastic splash/debris guards infront of the drivers wheel. should be 4 underneith and 3 in the wheel well. disconnecting the left side of the bumper would help too.
5. next pull the plastic in the wheel well aside and ull see the moisture collection/silencer. remove this screw illustrated in red. the front is held in a clip which can be pulled out when u pull the unit toward the wheel. its also slipped into the the intake which just slips off. (the gen3 is a little tricker to get off and requiers removing 4 screws from the front and back fo the unit, ull need the short philips for this)
Gen4
Gen3
6. once u have removed the silencer its time to remove the remainder of the intake. the gen3 is easier to remove. the gen4 has a clip that holds it down that u can get to from under the battery tray. it takes some work but with the battery out and fusebox unbolted its pretty easy (removing in a rearward direction is the best way to get it out). this is the piece ur taking out.
7. now uve got it all out its time to run ur tubing. the gen 4 takes a little more work then the gen3 to snake it into the fender. on the gen4, make sure u release the wire harness(white clip acessable from fender) and push it OVER the tubing as u snake it into the fender. start from the engine bay and twist the tubing back and forth making sure u use ur other hand to guide it into the fender correctly from inside the fender. the gen4 is a tighter fit and may dent the tubing but wont damage it. TAKE YOUR TIME, rushing it will tear the tubing and make a headache for urself for both gens.
path into the fender(fuse box on the right)
inside fender
from engine bay
8. use the 3" coupling C clamp to attach the filter to the tubing. easiest way is to attach the clamp to the tubing first then attach that to the filter. now i used zip ties to elevate the filter and possition it in front of the bumper vents(gen3) but u can use whatever u want to do it.
in the event that u need to run hoses, simply make a hole in the tubing and insert the threaded side of the brass hose end nipple into the tube then use silicone sealant to seal and hold it in place(epoxy works too). then just connect the hoses.
replace the fuse box and battery and fire her up. if all hoses are plugged up right then ull have no codes and will be taking in cooler air for a fraction of the cost of prebuilt CAI.
thats about it. its ghetto and doesnt look the best but its the cheapest and in some cases one of the only ways to do a CAI. ive hd this same setup on 2 gen3s for over 2 years each and ive never had a problem.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 09-11-2007, 10:25 PM   #2 (permalink)
In Tents
ToyCam187's Avatar
View ToyCam187's Photo Gallery
Looks great, nice job.
ToyCam187 is offline   Reply With Quote
Old 09-11-2007, 10:30 PM   #3 (permalink)
View 99lecamry's Photo Gallery
4th Generation
me personally im not a big fan of that tubing. i work on washers and dryers for a living and cant stand that vent tubing cause it cruches very easily and once it tears or starts to come apart foget it and that isnt such a good thing for ur cars intake. especially if u dont know its torn. my opinion tho either way nice job
99lecamry is offline   Reply With Quote
Old 09-11-2007, 10:41 PM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
yeah thats why ya have to be careful. i personally have never torn any but like i said ya have to take ur time. plus i dont expand it which is what causes it to weaken. but opinions valued, i realize this is an unorthodox way to do it.
R.I.P.
Car Domain:
Old 09-11-2007, 10:45 PM   #5 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
hell it worked for me back when i tried it
94' Camry V6 - Sold
96' Lexus SC400 - Crashed by brother
93' Lexus SC300 Turbo - Jackass ran a light and slammed into me
99' GS300 - Sold
02' Subaru WRX Turbo
Curry is offline   Reply With Quote
Old 09-11-2007, 10:51 PM   #6 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
how did it sound? did you notice any difference..
Black95Cam is offline   Reply With Quote
Old 09-11-2007, 10:58 PM   #7 (permalink)
I HAS BOOST!!!
bigbird's Avatar
sounds great, pretty much like the SIR. ur really not going to feel much differance in terms of hp. when its cold out i did notice a slight pickup but thats not confirmed nor was it significant. this is mostly for piece of mind, every engine like colder air.
R.I.P.
Car Domain:
Old 09-11-2007, 11:08 PM   #8 (permalink)
Black95Cam's Avatar
yeah.. i just want it to sound good.. like how i have it right now.. its sound okay. but i want to increase the sound.. but i sure will give this a try...
Old 09-11-2007, 11:23 PM   #9 (permalink)
Green Gang
View 213solider's Photo Gallery
interresting
Camry TRD
213solider is offline   Reply With Quote
Old 09-11-2007, 11:38 PM   #10 (permalink)
Lone star
blackhawk's Avatar
View blackhawk's Photo Gallery
perfect for a college student
I HAVE NO IDEA HOW THIS WORKS
blackhawk is offline   Reply With Quote
Old 09-11-2007, 11:40 PM   #11 (permalink)
I HAS BOOST!!!
bigbird's Avatar
designed by and for a college student
R.I.P.
Car Domain:
Old 09-11-2007, 11:42 PM   #12 (permalink)
Black95Cam's Avatar
yup, like me. =D gotta go cheap for the time being then once im done with college, then i could do the real mods. =D
Old 09-12-2007, 03:37 AM   #13 (permalink)
It's pronounced "Nesquik"
View N35QU!K's Photo Gallery
Looks pretty good. I've pretty much gone the cheap route in terms of my intake system (Spectre Pipe, Spectre High-Flow Air Intake, a total of $70), and it sounds badass I could put some before and after videos up if you guys really wanna hear/see.
But yeah, lately, i've been trying to figure out a way to get more cold air to the filter, and this little mod looks like it just might do the trick; i was wondering where I might find some cheap piping, and voila, you have answered my prayers.
Great job with the mod!
Click image for vehicle info (UPDATED 12.01.09)
N35QU!K is offline   Reply With Quote
Old 09-12-2007, 10:40 AM   #14 (permalink)
Official TN PimP
Dawgz's Avatar
View Dawgz's Photo Gallery
Or, u can opt for the CAI extension for the Injen intake :-P
Blah
Dawgz is offline   Reply With Quote
Old 09-12-2007, 10:42 AM   #15 (permalink)
Official TN PimP
Dawgz's Avatar
an older pic...but diffrent angle shot
Blah
AEM CAI for 92-96 Camry V6 toyrolla 3rd & 4th Generation (1992–1996 & 1997–2001) 5 08-08-2003 04:37 PM
link for DIY CAI? PeaZs Camry & Solara Lounge 3 10-01-2002 10:57 PM
Need Step by Step Intructions for CAI for Gen3 Camry V6 EasyE Hardcore Tech and Competition 0 07-22-2002 07:11 PM
