Several of the machine shops that I once used routinely cut the valves or the valves seats incorrectly, so that there wouldn't be any compression. I would put the entire engine back together, and get very frustrated because it wouldn't fire up. ...
Couldn't be too confident about a compression test, with new rings, pistons.
Eventually, pulled the heads and had them reworked. ...Didn't have time to argue with the shop .... just found someplace else to get the heads worked on.
Where are you in West Texas? .... Big Bend is great.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
