High Idle, PO441 Code & Poor MPG. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-13-2007, 10:14 AM   #1 (permalink)
View TriumphGT6's Photo Gallery
Vehicle:
1998 5SFE Auto Camry
Mileage: 153k miles
Driving Style: My mom drives it around 3 - 4k a year in Suburbia like an old lady.
BACKGROUND INFO
The engine was rebuilt at 143k, as when I bought it, it had a bearing sanded almost through in the bottom end. During the rebuild, I ended up doing a bore job complete with new pistons and rings(and 1 rod), the head was resurfaced and the crank was ground and new bearings were installed. New seals throughout, new timing belt and water pump as well. It runs and drives fine.
I also was able to make PepBoys honor a misprinted coupon for $20 Bosch O2 Sensors and I bought both up and downstream sensors and installed those. It helped economy reach high teens and low 20s as far as city/highway mpg. The fuel filter, IAC and many other economy related items were replaced during the rebuild.
I installed new NGK wires, and some cheapy autolite plugs(may be an issue from what I've heard, but they've been great in all of our domestics). Oil is changed every 3k and was switched to Mobil 1 oil and Mobil 1 Filters after 1k miles after the rebuild.
PROBLEMS
  • The Idle at start goes way high(1500 - 2000RPM) and stays there for several minutes, shouldn't take that long. Once warm it settles down.
  • Fuel Economy is never near what it should, a rebuilt engine gets less, but it gets around 22 on the highway driving real easy.
  • It has a check engine light for the EVAP system, the gas cap has been replaced but it's still there. All of the hoses going to the VSV have been replaced as well. How bad could this effect fuel economy?
Any suggestions are very much appreciated!
Rides
Toys - 1973 Honda ST90; 1983 Honda V45 Magna; 1987 Chevrolet Corvette Convertible
Daily Stuff - 1991 Lincoln Town Car; 1996 Saturn SL1 (Traded 98 Camry to my Mom for this)
TriumphGT6 is offline   Reply With Quote
Old 09-13-2007, 11:56 AM   #2 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Bosch O2 sensors SUCK on the camry. Id replace those with NGK or Denso brand.
check www.sparkplugs.com and get the universal ones and just solder your original connector inline.
Ill be replacing mine soon..as im having problems getting good gas mileage as well.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
High idle speed with P0505 and P0300 code Ahad Archived Corolla threads 2 08-31-2007 11:15 AM
High Idle Problem Remains... 93corolla5speed Older Generations (1969-1987) 7 07-29-2007 09:25 AM
2002 Corolla - high idle, no CEL 93corolla5speed Archived Corolla threads 2 07-24-2007 09:07 PM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
Abnormally high idle 3S-FE CMD88 Camry & Solara Lounge 0 10-28-2003 06:52 PM
