1996 Camry Keyless Entry Programming Help! Please - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-14-2007, 03:58 AM   #1 (permalink)
View flamerid's Photo Gallery
Exclamation 1996 Camry Keyless Entry Programming Help! Please
The car I bought didn't come with a keyless remote so I just bought one. I need help programming it though, how do I do this?
(Factory model 2 button remote Camry LE)
Please help!
flamerid is offline   Reply With Quote
Old 09-14-2007, 05:03 PM   #2 (permalink)
View 1996camry's Photo Gallery
I bought 96 camry Le 5sfe 4 cylinder does not come with Keyless...can you tell me information (what model) where you get the keyless and how much? never trust saleman(dealership) because they promise to send me a keyless after i got the car...two weeks i call back, they say keyless (loss or misplay) some where...
1996camry is offline   Reply With Quote
Old 09-15-2007, 11:04 AM   #3 (permalink)
It has a factory model keyless so the 96 'should' have keyless access if it has power doors.
It's called BAB237131.
They're all over the internet. They're very expensive though and a lot of places want nearly 100 for them. I was lucky to find a used one online for 45. Try looking around.
Old 09-15-2007, 11:14 PM   #4 (permalink)
Toyota Technician
-=]KaiN[=-'s Avatar
View -=]KaiN[=-'s Photo Gallery
Please help!
send me a pic of your remote and i can get you the programming instructions at work monday....
-=]KaiN[=- is offline   Reply With Quote
Old 09-18-2007, 07:58 PM   #5 (permalink)
View bishop12's Photo Gallery
Computer Assys, Transponder Key 89780-YF011
Hi,
I have a single button transponder key for a 1997 Camry. Lost the working remote and can't start the car. Are you able to supply instructions to melangcake@aol.com. Would be greatly appreciated
bishop12 is offline   Reply With Quote
Old 09-18-2007, 09:07 PM   #6 (permalink)
Toyota Technician
-=]KaiN[=-'s Avatar
Originally Posted by bishop12
Hi,
can do i sent you an email, hit me back and we'll see if we can get it figured out for you.
Old 09-19-2007, 08:11 PM   #7 (permalink)
Has anyone has instruction how to programming model BAB237131 keyless remote? my email is an_hello2000@yahoo.com
thank you for sharing the instruction.and i want to get a keyless remote for a long time on my 96 Toyota Camry Le 4 cycylinder 5sfe engine.. please help me!
Old 09-20-2007, 08:46 AM   #8 (permalink)
View deekay140's Photo Gallery
is the remote square or kinda oval?
deekay140 is offline   Reply With Quote
Old 09-20-2007, 11:55 AM   #9 (permalink)
5S-FU
View Sniperdude's Photo Gallery
Wait, wait, wait. Are you saying that all the LE 5SFE models with power doors have keyless entry?
I only have keys for my 1996 LE, how would I go about programming it for a wireless keyfob thingy?
Sniperdude is offline   Reply With Quote
Old 09-21-2007, 07:01 PM   #10 (permalink)
Toyota Technician
-=]KaiN[=-'s Avatar
in 96 most of the keyless was toyota tds system. A square remote one button and had TDS written in red on the remote. Look at the kick panel on the driver side and there should be a small toggle switch down there for programming and vallay mode selection. No switch no tds. If your remote was kinda oval and attached to the key then you have securikey+ which is my favorite system, but not very common on 96 most were 97 and up
Old 09-21-2007, 11:17 PM   #11 (permalink)
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
Huh sorry but do you mean you can just buy a factory remote and program it and it'll work right away? Why do people buy aftermarket remote starters and such then?
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Maim Menu is offline   Reply With Quote
Old 09-22-2007, 05:33 AM   #12 (permalink)
5S-FU
So, on the kick panel or underneath it?
Old 09-22-2007, 10:58 AM   #13 (permalink)
Toyota Technician
-=]KaiN[=-'s Avatar
usually they drilled a hole in the kickpanel itself to mount the switch, but ive seen them above them, or hanging behind the kickpanel.
Old 10-04-2007, 08:06 PM   #14 (permalink)
View jdave5917's Photo Gallery
Sounds like you are pretty knowledgeable on the security systems, so maybe you can help me. I have a very late '96 Camry (purchased late August 96) with factory-installed V.I.P. RS3000 (oval remotes) system. The piezo chirper stopped working some time ago, so it's not always easy to know if I'm setting or releasing the security system - particularly during bright days when it's difficult to see the lights flash. The system works as it's supposed to in all other respects. My problem is that since the piezo no longer sounds off, I can't locate it to check whether it works when direct current supplied to it. Any idea where they mounted that part?
jdave5917 is offline   Reply With Quote
Old 10-04-2007, 10:20 PM   #15 (permalink)
Toyota Technician
-=]KaiN[=-'s Avatar
I'll check the install manuals at work and get back with you.
Keyless Entry Programming Instructions for 2007 Camry Kidd07 Audio, Video, and Security - Tech 3 01-07-2011 07:46 AM
Camry keyless entry programming koobiidoobii 3rd & 4th Generation (1992–1996 & 1997–2001) 0 09-29-2006 02:27 PM
1999 Camry thief and keyless entry module zeno 3rd & 4th Generation (1992–1996 & 1997–2001) 0 08-31-2005 02:09 PM
keyless entry programming for 2000 corolla tmc Archived Corolla threads 1 09-30-2004 04:15 PM
94 camry keyless entry remote programming instructions amerellie 3rd & 4th Generation (1992–1996 & 1997–2001) 2 09-25-2004 11:15 AM
