I had similar problem before. It was my filler neck that leak due to all the rust on it. I tried different ways to fix the pipe, but it won't help, cox there is pressure inside the filler neck. I ended up buying a brand new filler neck from dealer, guess how much? almost 200 dollars~!!
Also, when you take off your OLD filler neck, there is a big chance that you will break the tube that connect the gas tank and the filler neck. This is because the plastic tube is all harden and cracked already, any stretch/pressure on it will break the tube!!
I fixed everything for around $250 CDN (including labour); labour is not expensive on this repair, only cost them around 30 mins in total. There were only a few bolts to loose and put back on during the whole repair.
I hope that helps
1993 Camry LE "5 spd" with 410k + ... still going~!
1985 Celica GT
1986 Celica GT "GONE"
