Using diff type of Oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-15-2007, 11:11 AM   #1 (permalink)
Rubbish.
jsl222's Avatar
View jsl222's Photo Gallery
My car is a 95 camry le..5sfe 2.2l On the cap, it says 10w30, but I accidently put 5w30. How will this affect my car? Also one more question: What type of Oil do you guys use? What company oil and filter? Thanks
jsl222 is offline   Reply With Quote
Old 09-15-2007, 11:49 AM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
It's not a problem.
Any major brand oil will be fine for 5000 miles. 10W-30 and 5W-30 are not a problem. 5W-30 will flow better at lower temperatures, but when warm, they are equal. 5W-30 is sometimes made from better stock than 10W-30.
The only filters I use are Napa Gold 1394 and 1396, and Purolator L14476, PL14476, L14477, and PL14477. The Purolator filters starting with P are a step up from the ones that start with L. Toyota filters would work fine also, but there is no dealer near me.
2007 Camry 2.4L 5M
Old 09-15-2007, 12:44 PM   #3 (permalink)
Yeah, that's me
View Silent Shadow's Photo Gallery
you can order a filter from toyota online, but it cost a bit more. i am poor so i get a high performance bosch filter, i think. its only lik 8 bucks. and i use 5W-30.
Silent Shadow is offline   Reply With Quote
Old 09-15-2007, 02:14 PM   #4 (permalink)
Napa Gold, which is a rebadged Wix, typically costs about $6 Purolator Premium (white can) runs $2.50 to $5 and the Purolator Pure One (blue can) costs about $4 to $6. Performance will be at least on par compared to Bosch.
2007 Camry 2.4L 5M
Old 09-15-2007, 02:19 PM   #5 (permalink)
xxswat718xx's Avatar
View xxswat718xx's Photo Gallery
Sorry to jack his thread BUt... I wanted to know what would happen if I put in synthetic oil in my 97 4cyl? I normally put in afew quarts of regular oil (10w or 5w) and a bottle of Marvel Mystery Oil. Runs great but just curious about the synthetic.
xxswat718xx is offline   Reply With Quote
Old 09-15-2007, 04:22 PM   #6 (permalink)
Yeah, that's me
all i know about synthetic is that you still have to change every 3K miles. i believe it has a better temp resistance.
Old 09-15-2007, 04:29 PM   #7 (permalink)
Yeah, that's me
also once you switch, you shouldn't switch back to natural
Old 09-15-2007, 04:51 PM   #8 (permalink)
View toyomoho's Photo Gallery
The major oil company’s state one can switch back and forth between synthetic and mineral oil or mix and match. There are oils that are a combo of mineral and synthetic.
I use the cheapest name brand oil I can find on sale and Wix filters.
Old 09-15-2007, 05:33 PM   #9 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
This is more of a myth than anything.
Synthetic oil is thicker than regular oil..and the reason people say not to switch back is probably because the thinner, regular oil is easier to leak than the thicker synthetic oil if there are small leaks....or more leaks could 'show themselves' if one switches from the thicker to the thinner oil.
My camry has 322,000 miles on it and has NEVER seen synthetic oil. The engine is still strong (though I have a small leak by the timing belt which I will fix as soon as money/time allows). I had a 92 accord that ran synthetic and had about 270,000 miles on it when it got towed away from being totalled out from an insurance claim. That engine was strong as well.
To tell you the truth...im glad to FINALLY be back to running regular, LESS EXPENSIVE oil
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 09-15-2007, 06:15 PM   #10 (permalink)
Wrong. Synthetic oil will last to at least 5000 miles like regular oil, if not longer. Changing any oil at 3000 miles is excessive and a waste.
Use whatever oil you like. Changing from synthetic to regular does nothing. If it did, the 5S-FE motor in my 00 Camry would have been dead long before I crashed it.
2007 Camry 2.4L 5M
Old 09-16-2007, 09:04 AM   #11 (permalink)
Yeah, that's me
toyota does not think so.
here is what someone wrote in another thread from customer care -
"However, it still bothers me that Toyota, on it's Customer Care Site, continues to state that if you go with Synthetic oil, you should not switch back. This is their statement: "If you decide to use synthetic oil for the engine, it is best not to switch until the first scheduled oil change. Synthetic oil should meet the specifications provided in your Owner's Manual. If synthetic oil is used, Toyota recommends that you continue to observe the oil change intervals laid forth in the Scheduled Maintenance Guide. Also, once synthetic oil is used, you should keep using it and not switch back and forth with natural petroleum-based oil". It just seems like there is something about Toyota engines that may cause a problem by switching oils, but they will not tell me what it is."
Old 09-16-2007, 09:59 AM   #12 (permalink)
View Bear95's Photo Gallery
http://www.toyautoparts.com/CAM-3-002_years.html
You can order OEM Toyo filters here and thay are not that costley.
Yes you can switch or mix both types of oil ( what do you think Syn Blend is?)
5/30w is recomended in the manual for cold temps.
Bear95 is offline   Reply With Quote
Old 09-17-2007, 11:54 AM   #13 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
thats whats i use, castrol syntec blend 5w30 and fram high milage HM 3614
Black95Cam is offline   Reply With Quote
2.7L oil capacity incorrect gonesurfing 2nd Generation (2005+) 34 02-11-2011 12:09 PM
Toyota Stand on Synthetic Oil siennavan General Discussion 51 12-09-2007 09:00 AM
Motor oil for diff? Julio Bro! Archived Corolla threads 17 05-16-2007 02:25 AM
Another oil change horror story! witxp 5th & 6th Generation (2002-2006 & 2007-2011) 16 05-13-2007 12:29 PM
Sure was fun changing my oil today... Infinitrium Archived Corolla threads 18 10-12-2006 08:38 PM
