Originally Posted by PatrixUSA
Eye8Pussies post:
"It was most likely me who posted the original fact, as I asked my mechanic about this years ago when there was basically no way that I could get my diff drain bolt off after so many years of not being touched.
the 4banger tranny has entirely separate diffs and tranny
the v6 transmission shares the same fluid with two different drains and refills, so technically, enough changes of the regular tranny drain and fill will change all the fluid in the tranny eventually including the differential"
Is the 1996 V6 (Gen 3.5) system is exactly the same as the 1994 V6 (G.3) ?
I just want to be sure.
Does this apply to a 1994 Camry V6 as well (my father's car) ?
If I drain the differential fluid without removing the differential-fill plug, will a fill-up through the transmission-fluid pipe fill up the depleted differential too ?
Thank you everyone.
