knocking sound when cold - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-15-2007, 05:11 PM   #1 (permalink)
View hoiskii's Photo Gallery
Hi,
about 1 kmiles ago i've changed the timing belt (etc.). Now, when the car is cold i hear a knocking sound at ~1500 rpm and higher. The sound comes from the valve cover area. When the car warms up (after ~5-10 mins) the knocking goes away completely.
What is it?
How to fix it?
Thanks.
hoiskii is offline   Reply With Quote
Old 09-15-2007, 05:14 PM   #2 (permalink)
Former Gen 4.5 owner
View Arisotezza18's Photo Gallery
I have this same problem. Right when i start the car and start driving i hear the knocking, but it goes away after driving around for a few minutes. It sounds like a loose shield or something. I haven't had the chance to check out the problem. Anyone have any ideas on what it might be?
Arisotezza18 is offline   Reply With Quote
Old 09-15-2007, 10:59 PM   #3 (permalink)
Toyota Technician
-=]KaiN[=-'s Avatar
View -=]KaiN[=-'s Photo Gallery
off the top of my head a bad t-belt idler a loose front cover, p/s belt hitting the t-belt cover, not sure exactly but if it just started after t-belt install something is up if we are talking 5s-fe then you might not have got the belt tight enough and its slapping the cover as it turns. happy hunting...
-=]KaiN[=- is offline   Reply With Quote
Old 09-15-2007, 11:20 PM   #4 (permalink)
... maybe remove top timing belt cover and examine upper region of belt for slack. Should be relatively little deflection on either side of cam shaft pulley. .... also look at symmetry of deflection .... should be about the same with respect to cam pulley. .... Probably check lineup of timing marks while you are there.
... There is a specific method to be used when finally tightening idler pulley to complete timing belt installation .... after timing marks are aligned ... involves rotating crankshaft so many turns, etc. ... see repair manual section. .... might as well check this as well.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 09-16-2007, 10:06 AM   #5 (permalink)
Hi all again,
As I said the sounds comes from the valve cover area, not the TB cover area. The TB is silent and nice, I've followed all the proper procedures for setting the correct tension of the TB. I thought that from my post you would immediately find it out that I suspect the valve timing/valve gap settings. Now I am a bit worried about my TB since none of you said anything about valves. But anyway there is nothing in the TB area (except the WP probably) that changes the temperature as the engine warms up.
Old 09-16-2007, 01:36 PM   #6 (permalink)
Originally Posted by hoiskii
Hi all again,
.... my post was not so much concerned about the timing belt itself, rather what it does... positioning the cam shafts. .... Just guessing though ..... maybe something to check out if you can't come up with anything else.
Does your engine make this sound when cold? montreal 1st Generation (2003-2008) 52 12-29-2007 07:56 AM
car knocking, runs better cold CodyjCA Archived Corolla threads 5 12-15-2004 01:34 PM
Knocking sound when car in motion help pls? 94_v6_camry Camry & Solara Lounge 7 10-08-2004 09:48 PM
Knocking sound Gen3 gqdabien 3rd & 4th Generation (1992–1996 & 1997–2001) 0 09-22-2003 08:53 PM
