fuel problem? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-16-2007, 10:38 AM   #1 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
fuel problem?
so 96 v6 m/t.
so i try and start it up and it just stumbles out.
after a few trys it idles at 800 or so rpm no fast idle.
touch the gas even after letting it idle for 5 min stumbles out and dies,
i know the engine wants to run because it really trys to come back from when it stumbles out.
so far replaced the fuel filter, air filter, and cleaned the maf sensor.
i disconected the ect to throw the ecu in open loop mode didnt help.
changing the filter helped a wee bit.
the night before all this the engine was racing like a champ.
^ and leaving it that way!
Old 09-16-2007, 11:17 AM   #2 (permalink)
View hoiskii's Photo Gallery
Does the idle come back to normal after 10 mins, 15 mins?
Does touching the gas help to start the engine?
Anyway it sounds pretty much to me as the Idle Control Valve problem.
If your car was fine a night before, then it might also be some wire problem, try to reconnect some of the wires, MAF, ICV, etc.
hoiskii is offline   Reply With Quote
Old 09-16-2007, 03:05 PM   #3 (permalink)
Toyota Technician
-=]KaiN[=-'s Avatar
View -=]KaiN[=-'s Photo Gallery
chk fuel pressure at idle should be about 48psi, and i agree with hoiskii sounds more like a iac valve problem to me.
-=]KaiN[=- is offline   Reply With Quote
Old 09-17-2007, 01:54 PM   #4 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Just out of curiosity, check the connections of the air hose that supplies the throttle body. Also look for cracks & breaks. Anything that would leak air. Since it was running great the night before I doubt this is the cause but...
Kep
Old 09-17-2007, 07:41 PM   #5 (permalink)
Toyota Technician
-=]KaiN[=-'s Avatar
Kep
yep any air entering the engine after the air flow meter will make them doing funny things, die, misfire, all kinds of driveability issues. Good advice.
Old 02-22-2011, 05:40 PM   #6 (permalink)
96 3MZ M/T
chronoti's Avatar
ya so this turned out to be a bad ecu
Old 02-22-2011, 05:43 PM   #7 (permalink)
96 3MZ M/T
chronoti's Avatar
well brought this back because i didn't want a new thread
so some days when i start her i have a low idle like 400rpm reeks of unburnt fuel, then after like 15 seconds kick right up to 2k rpms.
so this the iac sticking and choking the engine right? or am i in some kind of crazy fest where i need cry my self asleep trying to figure out?
so far done it 3 times in the last month. like i said i think the iac is just freezing
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 01:17 PM
2001 Corolla Starting problem - Fuel Filter theguy 8th Generation (1998-2002) 6 12-31-2008 10:42 PM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
'93 pickup on 3 of 4 cylinders, possibley fuel problem? monroe 89-95 Toyota Pickup/Hilux 2 04-30-2006 07:15 PM
Fuel or Electric problem racerui Tercel, Paseo, Starlet, and Sera Forum 2 06-06-2005 05:27 PM
