4-cyl swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-16-2007, 09:53 PM   #1 (permalink)
View faterotong's Photo Gallery
Canada 4-cyl swap
Hi guys, first time post here.
I have a 1993 Camry LE with the 4-cyl and auto. Recently, the engine took a dump on me. When I got the car, it already had an oil leak. I kept my eye on the engine level quite often. Despite that, the engine died on me coming back from school last week. It was hard to start after that and I had to give it gas to keep it running or else it would die. After that, I would hear tapping noises from the engine head.
The car's been parked ever since and I've only started it up for a few seconds at a time to hear more distinctly what the noise was like. The thing I noticed is that when it's cold, the engine will stay perfectly running without shaking so I'm pretty sure the rotating assembly is still in good shape.
I personally think the valvetrain is shot but I haven't had the time to tear the engine open yet. So right now I'm actively searching for a 5SFE and a manual transmission to do a tranny swap at the same time. I've searched the forums for threads regarding transmission swaps and I saw a link about someone swapping a manual tranny in a V6 model, but the links don't work anymore?
So far, I've found a 5SFE and a manual transmission out of a 1991 Celica with around 165,000KMs on it. The guy doesn't know if the engine runs or not, but he was told by the previous owner that it did and the tranny has apparantly been rebuilt so therefore has 0 mileage on it.
My question is, will all of his stuff fit in my Camry? I'm questioning whether the shifter cables, shifter, brake pedal assembly and other assorted parts would work? Do I need Camry specific axles? I heard that I might also need to swap hubs? Is this true? Also, he doesn't have the ECU, so if I use my current ECU, is there a way to trick the car into thinking that everything is fine and that the auto tranny is still there?
Thanks again guys!
Nick
Also, if I understand right, I need the following parts:
Engine
Tranny
Clutch
Flywheel
Clutch Master Cylinder
Shifter Cables
Shifter
ECU
Did I miss anything?
faterotong is offline   Reply With Quote
Old 09-17-2007, 02:42 PM   #2 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $294873
View Buurin's Photo Gallery
Your priority here is changing the engine. Unless you are like me and REALLY want to do a manual conversion project, you don't need to go that far. Just investigate if that Celi 5S mates to your tranny (no reason why it wouldn't), and if your ECU can run it (which you do want to find out). Another thing is I don't know about Quebec, but some jurisdictions frown on swapping in older engines for "emissions" reasons.
I suggest you hold off on acquiring the manual tranny parts until you sort the above out.
And welcome to TN.
Buy my parts
Buy my other stuff
Buurin is online now   Reply With Quote
Old 09-17-2007, 03:29 PM   #3 (permalink)
Thanks for the welcome. I don't think there should be any problem with swapping in the older engine/tranny. Plenty of people do it. I can't think of any reason why it wouldn't be allowed.
I thought to myself I might as well do the manual swap cuz I'm really sick of driving auto and with the amount of money I'm spending, I really don't mind doing it.
I've been told that the parts will fit in the Camry from a reputable shop that deals with Toyotas here and the only thing that might not fit would be the axles.
And yes, I REALLY want to do the tranny swap. :P
Old 09-17-2007, 04:07 PM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
everything should fit just fine
if the axles don't fit, you can always just look up some 5sfe manual axles
HaHa
4age 20v vs b18 swap good_old_geo Archived Corolla threads 15 08-28-2006 07:37 PM
Supra Specs and time frames? glish_dreams Supra Forum 17 04-17-2006 11:14 PM
22r cyl head swap onto a 22re 1lowryd 89-95 Toyota Pickup/Hilux 4 03-31-2006 08:10 PM
clutch slipping after clutch master cyl + slave cyl replacement? msingletary Pre-88 Toyota Pickup/Hilux 3 03-15-2006 02:01 AM
5MGE to 7MGTE swap question??? turbo_tercel Supra Forum 1 03-30-2005 07:44 AM
