Somethings wrong with my hood latch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-17-2007, 11:01 AM   #1 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
Question Somethings wrong with my hood latch
After the accident, my hood latch is acting funny, Im not sure the the front of the car was pushed in slightly because it looks like most of the impact was on the bumper absorber and reinforcer, but the hood closes fine except when i want to open it, it doesn't pop up like before. I'll eitehr have to shove a ball of paper to hold the latch ( inside the car ) open until i go out and left it up. Otherwise, i can pull the latch within he car adn the hood remains closed. Also i've noticed that the hood in slightly higher on the drivers side than passengers side which is aligned with the body panel of the car. Any suggestions, i tried searching but there's no help it either says get a new latch or hood pins, but the latch is working since the hood remains closed but when i open it the latch ( inside the car to opedn the hood ) has to remain pulled so i cna left the hood up.
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 09-17-2007, 12:20 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
sounds like the rad support is bent. most likly its bent foward so it not releasing the hood right. either fix or replace the support. its pretty flimsy where the latch is mounted so it should be to hard to bend back.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 09-17-2007, 01:09 PM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
It is probably out of alignment. You might try to spray some lubricant (I used that white lithium grease spray) around the latch. It might work until you get it lined back up. When my 90 Camry did that (age not alignment) I was able to rap it on the back edge by the windshield wipers after I pulled the handle and the hood popped right up. Then I tried the lube and it worked just fine...
Kep
Old 09-17-2007, 05:54 PM   #4 (permalink)
Creeps228's Avatar
So would i have to remove the bumper again?
But how can it be not aligned when everything looks to be intack?
MR2: 7A-GE
Old 09-17-2007, 06:00 PM   #5 (permalink)
I HAS BOOST!!!
bigbird's Avatar
just cuz it looks intact dont mean it is. somthing must be wrong with either the hood, hood latch loop, rad support or the latch itself.
R.I.P.
Car Domain:
Old 09-17-2007, 07:20 PM   #6 (permalink)
View moocow's Photo Gallery
I rear ended someone a couple years back. Since then my hood has never been the same. I got it banged out so its straightened again, but the hood release lever never gives that "click" that opens the hood. I have to stick a beer bottle opener under the hood release and then go to the front of the car and lift the hood up. Totally ghetto man
moocow is offline   Reply With Quote
Old 09-17-2007, 08:17 PM   #7 (permalink)
Creeps228's Avatar
well ima see what i can do on thursday when i drop the car off for repair
MR2: 7A-GE
Old 09-18-2007, 10:56 AM   #8 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
"why no officer, i wasnt drinking. that beer bottle is a tool i use to open the hood on my car..."
Old 09-18-2007, 12:46 PM   #9 (permalink)
Kep
Kep's Avatar
I don't see why you would need to remove the bumper. If it is visually close to alignment you should be able to fuss with the latch and the latch loop to get them out of a bind. Do try the lube first. It is simple. That may be all you need.
Kep
Old 09-18-2007, 12:50 PM   #10 (permalink)
5S-FU
View Sniperdude's Photo Gallery
I think I've used that line before. Doesn't work.
Sniperdude is offline   Reply With Quote
Old 09-18-2007, 01:29 PM   #11 (permalink)
View nevanerviss's Photo Gallery
[threadjack] How difficult is that to change? The upper rad support, I mean? [/threadjack]
nevanerviss is offline   Reply With Quote
Old 09-20-2007, 06:44 PM   #12 (permalink)
Creeps228's Avatar
no problem nevanerviss
umm there was nothing, nothing was bent, one of my neighbors works for a body shop for german cars, he said all that the latch need was some lubrication and the hodd was sort of bent so we rebetn it into shape you can say now it opens normally thanks fo reveryone who help and nevanerviss hopefully some answers you question
MR2: 7A-GE
HELP! Can't find hood release on 1986 Toyota Van... zzzHopperzzz 1st Generation (2001–2007) 1 05-31-2006 11:49 PM
quick help needed with hood latch archangel571 Camry & Solara Lounge 5 01-02-2006 04:17 PM
Hood Latch prob with '05 Camry????? ASG14 5th & 6th Generation (2002-2006 & 2007-2011) 14 02-25-2005 09:51 PM
somethings wrong!! gasman MR2 Forum 10 02-24-2004 12:25 PM
