Cranks, Wont Start...need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-20-2007, 05:39 AM   #1 (permalink)
View decoder's Photo Gallery
'94 Camry, 4 cylinder
OK here's some details: I cranked the car but only turned the key for about a second(my fault) so it didnt start. I tried to recrank it but now just keeps turning. I checked for spark, gas - checked ok. I did notice 2 cracks in the intake hose but I taped those up....still nothing. Can anyone suggest anything?
I thought about the Air Flow Meter but wouldnt the check engine light be on, mine is not?
Also, is it possible that i put too much gas in the engine when i tried to turn it the first & second time...so it's "flooded"?
decoder is online now   Reply With Quote
Old 09-20-2007, 07:03 AM   #2 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
let it sit for 20 minutes and give it another go. a check engine light wont pop up until after the car is running.
Old 09-20-2007, 07:22 AM   #3 (permalink)
I tried to wait about 10 min the first time it didnt start but still nothing
Ive left the car at work overnight, so it has had enough time to sit. So, Ill try it again.
What do you think happened?
Old 09-20-2007, 08:02 AM   #4 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
Well, if you checked and verified spark and fuel, then you'd be missing either air or compression. Does it sound different at all now when it cranks? When timing belts break, they usually do so at start up.
When you checked for spark, did you pull the plug(s) out?
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 09-20-2007, 09:20 AM   #5 (permalink)
View MisterArdovino's Photo Gallery
Fuel pump...
MisterArdovino is offline   Reply With Quote
Old 09-22-2007, 08:38 AM   #6 (permalink)
no, all these things are ok
I unplugged the IAT(Intake Air Temperature) sensor, tried to start it & and it started right up but the check engine light was on. I plugged it back in & now everthing seems fine. Starts up normal without engine light.
I don't know exactly why this would be keeping the car from starting. According to the Haynes manual, it says it "acts as a resistor which changes value according to the temperature of the air entering the engine."
Well, does this mean I need to clean or replace something? I cleaned the throttle body about 8 months ago & plan on changing the PCV valve and air filter.
Is there anything else I should think about replacing?
'94-I4-205k
Old 09-22-2007, 11:28 AM   #7 (permalink)
'94-I4-205k
Several sensors supply data to the engine control unit. The ECU uses the factors to determine values such as injector pulse width, spark timing, etc. If your IAT is out of spec, you might not have an immediate start combination .... too rich, too lean, or something else.
In the diagnostic section of the repair manual, there is a description of how to test the IAT using a resistance meter ... giving resistance values at various temperatures.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
EFI super weird start problem chrices 89-95 Toyota Pickup/Hilux 3 08-08-2007 08:14 PM
Car cranks but won't start? sleepie Archived Corolla threads 13 12-28-2005 05:42 PM
Recaros Start seats are now just $195.95! Buy last years close out fabrics and save! Safe Drives Supporting Vendor Sales 0 11-09-2005 07:17 PM
Cold Start Switch 86CRESSIDA86 General Discussion 7 01-07-2002 10:10 PM
