removing fuel pump - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-20-2007, 02:07 PM   #1 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
removing fuel pump
that fricking thing wount come loose.
i have box wrenches for it and when i try to loosen it it starts to bend and then i stop because i dont want to break it blah blah blah any way to get the damn pump out other than breaking something?
^ and leaving it that way!
Old 09-20-2007, 02:53 PM   #2 (permalink)
Can you put one wrench on each nut? .... Place wrench handles so that they are just offset from each other ... maybe 20 or 30 degrees apart. Then squeeze both handles so that the two nuts come apart .... make sure that you apply force in the correct direction, so that they come apart .... not go together.
If you have already damaged the faces on one of the nuts, you will have to resort to vice grips or maybe a pipe wrench on that one. However, the two wrench offset technique ought to work, if you set it up correctly.
Actually, I think that you are supposed to use flare nut wrenches on this type of assembly .... to avoid damaging the nuts. Open end wrenches might work ... or maybe not.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 09-20-2007, 03:14 PM   #3 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
locking pliers tight enough to dig into the nuts....
but in reality, I have to say that I ended up just cutting mine off when I replaced my pump with a high flow one, and then clamped the lines with fuel line clamps and high pressure fuel hoses
works just as well
HaHa
T100 Fuel Pump Question toyotakev T-100 1 08-28-2007 09:16 AM
help newbie save '85 with fuel system problem leiniesred MR2 Forum 0 02-28-2005 09:49 PM
