Need Brake HELP - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-20-2007, 08:16 PM   #1 (permalink)
View AtoZed's Photo Gallery
Need Brake HELP
I posted an earlier thread about changing out brake line from 92 Camry DX without ABS. This is from rear passenger wheel to master cylinder. I just got line from Toyota but I don't know which line of the master cylinder that that wheel connects to. Can someone please help? I can't follow old line. I just wnat to run this new line while leaving the old one in place.
Toyota manual doesn't seem to be much help for this. At least I can't seem to find it.
Thanks in advance.
AtoZed is offline   Reply With Quote
Old 09-22-2007, 11:44 AM   #2 (permalink)
Toyota Technician
-=]KaiN[=-'s Avatar
View -=]KaiN[=-'s Photo Gallery
i don't know about leaving the old line in place....I would probably remove the old line and put the new one in its place. Just disconnect at the wheel, and remove line all the way to the master cylinder, or if the car has a junction valve all the way to it. Then there won't be any doubt where it goes.
-=]KaiN[=- is offline   Reply With Quote
94 Camry brake warning light eaglemtn 3rd & 4th Generation (1992–1996 & 1997–2001) 25 05-04-2012 11:57 AM
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
Rear Drum Brakes Syndacate Tercel, Paseo, Starlet, and Sera Forum 13 08-20-2007 02:56 PM
Brand new brake pads, brake pedal still bottoms out!! izekat Tercel, Paseo, Starlet, and Sera Forum 6 06-26-2005 11:35 AM
Good discussion on x-drilled/slotted brakes EKam Hardcore Tech and Competition 44 12-29-2003 11:46 AM
