Brake Fluid GEN4 =) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-21-2007, 04:20 PM   #1 (permalink)
View Spike23's Photo Gallery
Brake Fluid GEN4 =)
I have a Camry XLE 1997, wanted to change the rotors and bleed the brakes.
I forgot where i left my manual and i did a search but couldn't find out. Does my vehicle use a DOT 4 or DOT 3? =) thanks.
Spike23 is offline   Reply With Quote
Old 09-21-2007, 04:23 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
dot 3, but dot 4 will work too
HaHa
Old 09-21-2007, 04:24 PM   #3 (permalink)
Ok thanks man =), i just purchased a DOT 4 earlier lol. So in the clear.
Old 09-21-2007, 06:23 PM   #4 (permalink)
Import Tuning
camry man68's Avatar
View camry man68's Photo Gallery
what brand did you buy?
camry man68 is offline   Reply With Quote
Old 09-21-2007, 07:31 PM   #5 (permalink)
Its prestone dot 4
Looks like this http://ec1.images-amazon.com/images/...PL._AA160_.jpg
Old 09-21-2007, 11:02 PM   #6 (permalink)
Import Tuning
good choice, prestone, valvoline and castrol are really good brands.
Old 09-21-2007, 11:03 PM   #7 (permalink)
Also since i am on the topic =).
Would you guys know the torque specs for the wheel and rotors?
I am going to put that on tommorow.
I recall reading 80 ilbs for the wheels lug nuts. Also i wnated to ask what type of grease should i buy? for the caliper pin
i remember using a kind of grease but no sure which to lube it back.
But i would like to know the torque for the rotors =D. Thanks guys really appreciate the help.
Old 09-21-2007, 11:09 PM   #8 (permalink)
View importcar's Photo Gallery
how do you know when the rotors need replacing?
importcar is offline   Reply With Quote
Old 09-21-2007, 11:11 PM   #9 (permalink)
When its vibrating like heck =) like mine. LOL
You can use a mircometer to see the specs to measure run out. There is a factor spec. Also sometimes visually like you can visually see warpage.
Old 09-22-2007, 08:49 AM   #10 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
bleed the hell out of your brakes! the original fluid is dot 3 and it is listed on the brake fluid reservior cap.
theres no real torque spec for the rotors.
its about 83 pounds for the lugs
areyou speaking about grease for the brake pads or grease for the calliper sliding pin (13mm upper bolt). Brake pads you can just get any anti squeel (highly recommended to do so), and the other calliper bolt you can use anti squeel grease too if you want since you just need something that can withstand high temps. I am assuming also that you're getting new brake pads too.
are you just replacing to OEM rotors or brembo blanks? those are the way to go if u havent already gotten ur rotors.
nodrogkam is offline   Reply With Quote
Old 09-22-2007, 11:40 AM   #11 (permalink)
Well i am about to do them right now. The grease i bought now, it was just for the caliper guide pins. As for the brake pads..no using the old ones they are still fairly new.
The replacement rotors are the oem brembo replacements.
Old 09-22-2007, 04:48 PM   #12 (permalink)
Gameroom cash: $303055
For the caliper slide pins I would recommend "high temperature silicon disc brake grease".
As far as the wheel torque, 76 ft lbs is the exact figure, but most shops use an 80 ft lb torque stick. I use 80 ft lbs with my torque wrench.
Mike
Old 09-22-2007, 05:40 PM   #13 (permalink)
All done guys, thanks for all the feedback.
Got my new oem rotors on. Brakes well now. Drained pretty much all the dot 3 put in the prestone dot 4 ^___^ all in a day's work lol.
Anyhoo =) while doing the rotors. i saw my emergency brake pads were crap though..like really thin and about to fall out lol. I guess i should get a shop to do that some day..
I don't have the tools to do that =). I'll snap some pics tommorow i guess if anyone interested hehe.
Old 09-23-2007, 10:03 PM   #14 (permalink)
I'm interested in the pics. How long does it take to bleed the brakes? The dealer wants $110 to do mine.
Old 09-23-2007, 11:20 PM   #15 (permalink)
Hmm well it was quite simple for me. The reason being i had the tools. I have a decent jack and stands so just took a few mins. Then i use my air compressor to take off the wheels.
Prob took about 10mins or so. Just keep topping up the brake fluid and have someone help is much quicker.
Had a buddy of mine pump the brakes for me. If you have a friend who knows how to teach u to bleed the brakes that'd be better though. Is quite simple but you have to make sure its done right. Unscrew the bleed plug its like a size 8mm then let it drain for a bit. Shut it back then tell someone or u pop in the seat and pump the brake a few times till it gets hard. Then after that the person inside if helping you just tell them to hold the brake down or if not you go back outside and release the bleeder plug again the fluid will come out. Pretty much this whole process is to make sure no air is in the system. Crucial is checking the master cylinder and making sure the fluid is topped up so its not like running on no brake fluid=). So ya...hope that helps man.
Here's my parent's car all done. All new rotors =) brembo replacements.
Also sorry for the pictures..should of took pictures with the wheel off...but whatever. You all get the point.
In total the parts were like under 280usd or something the 4 rotors from Tirerack
Then i just went to my local car store to buy the Prestone Dot 4 brake fluid. Then lastly the guide pin grease...which were the weird black or green coloured type.
How to change transmission oil? How to change brake fluid? Pwr Steering Fluid?? oscaryu1 Camry & Solara Lounge 10 08-19-2007 05:32 PM
??'s about the nver needs changing AT fluid kn38ms 2nd Generation (2005+) 22 10-29-2006 07:42 PM
Purging brake fluid? Troyfrezze Camry & Solara Lounge 6 10-23-2005 03:11 AM
Dirty Brake Fluid chronoti Camry & Solara Lounge 1 02-17-2005 04:22 PM
Brake fluid for 93-97 Corolla Jaspher Archived Corolla threads 4 07-26-2003 10:07 PM
