3100 RPM at 75mph - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2007, 01:40 AM   #1 (permalink)
Threeacess3's Avatar
View Threeacess3's Photo Gallery
3rd Generation 3100 RPM at 75mph
My car rpm is at 2800 when i go 70 mph isn't it suppose to rev lower
Threeacess3 is offline   Reply With Quote
Old 09-22-2007, 02:02 AM   #2 (permalink)
xet
View xet's Photo Gallery
i think my v6 hits like 3k at 80 so yours prob isnt too far off
1998 camry xle v6 *no longer mine*
2005 G35 coupe 6mt
xet is offline   Reply With Quote
Old 09-22-2007, 07:11 AM   #3 (permalink)
rusty9's Avatar
Gameroom cash: $440305
View rusty9's Photo Gallery
some transmissions have trouble finding the right speed/rpm for overdrive. try going a touch faster or slower to find the sweet spot where it shifts.
rusty9 is offline   Reply With Quote
Old 09-22-2007, 08:20 AM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
that sounds about right
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 09-22-2007, 08:45 AM   #5 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
do you have a v6 or an i4? i believe their ratios run a little differently in that the i4's will run higher because the engine lacks torque so they tuned it to use more HP.
the v6 will hit 3K rpm at approx 82 mph.
nodrogkam is offline   Reply With Quote
Old 09-22-2007, 08:56 AM   #6 (permalink)
I have an I4. My 2003 Camry 2.4 liter hits 3000 RPM at 87 mph. Why does my 96 I4 rev higher at 75 mph ?
Old 09-22-2007, 09:33 AM   #7 (permalink)
View roastlechon's Photo Gallery
4th Generation
most likely because our camrys only have 4 gears on overdrive and 3 gears with no overdrive =/
i have the same problem when i drive
on main roads i make sure i drive as high as i can to hit the 2nd gear to slow down and use as less gas as possible at 1.4k rpm ish
roastlechon is offline   Reply With Quote
Old 09-22-2007, 10:09 AM   #8 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
Because it's not as powerful so it needs more power from the engine to drive at those speeds?
geoff5093 is offline   Reply With Quote
Old 09-22-2007, 10:19 AM   #9 (permalink)
View hoiskii's Photo Gallery
I agree. Even wind can make an effect on rpms at high speed.
My 99 I4 hits 3000 rpm somewhere between 75 and 80 mph. But 3100 at 70 seems to be a bit high, BUT there might be different transmission and engine on GEN 3 that makes this difference. All Hondas have rpms noticably higher, for example.
hoiskii is offline   Reply With Quote
Old 09-22-2007, 12:15 PM   #10 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
My 96 I4 will run 82mph @ 3000 rpm.
uibalnme is offline   Reply With Quote
Old 09-22-2007, 04:36 PM   #11 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
instead of bothering us with a continous bombardment of redundant questions, why don't you do the math that tells you the engine speed VS vehicle speed yourself.......................................... .................................................. .................................................. .....
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 09-22-2007, 07:06 PM   #12 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Why dont you elighten us with your INFINITE wisdom and let us know the equation so we can figure it out ourselves?!
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 09-22-2007, 10:31 PM   #13 (permalink)
Toysrme's Avatar
Cool
try googling gear ratio calculator for morons
newb
Now with Turbo!
Old 09-22-2007, 11:31 PM   #14 (permalink)
Thanks! You're an A-1 A-hole
You throw newb around like it's supposed to be an insult or something.....we are all 'newbs' at one point or another....oh but wait...I forgot you were born with your infinite knowledge. PLEASE.....excuseth our ignorance thou big-headed one!
Old 09-23-2007, 01:31 AM   #15 (permalink)
OMNI's Avatar
View OMNI's Photo Gallery
group hug
hoi hoi
OMNI is offline   Reply With Quote
rpm window switch misfire omegarex 3rd & 4th Generation (1992–1996 & 1997–2001) 2 01-14-2007 10:38 AM
"A" engine info freakinbox Archived Corolla threads 29 05-10-2006 12:05 AM
What the XRS needs. kini Archived Corolla threads 18 02-09-2005 10:37 AM
deciding on a car toyota vs mazda koss78a Archived Corolla threads 104 10-20-2004 12:15 PM
air fuel ratio questions... HPR Archived Corolla threads 12 12-02-2003 07:10 AM
