Power Window problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2007, 03:46 PM   #1 (permalink)
View louie1086's Photo Gallery
Hey guys, when I move the front driver's side window up, it jumps off the track an inch before it gets to the top. When it gets to the top, there is a 1/4 inch gap between the top of the window glass and the door.
Has anyone encountered this problem before? If so, how can I fix it? Any advice would be appreciated. Thanks!!!
louie1086 is offline   Reply With Quote
Old 09-22-2007, 07:59 PM   #2 (permalink)
Toyota Technician
-=]KaiN[=-'s Avatar
View -=]KaiN[=-'s Photo Gallery
sounds like a window regulator issue to me. Need to pull the door panel and see whats going on in there.
-=]KaiN[=- is offline   Reply With Quote
Old 09-22-2007, 09:43 PM   #3 (permalink)
The Slowest of Slow
tsibole90's Avatar
View tsibole90's Photo Gallery
the same exact problem just happened to me today... but yeah, take the door panel off and have a look at the regulator.
tsibole90 is offline   Reply With Quote
Old 09-23-2007, 01:05 PM   #4 (permalink)
what am i looking for in the regulator/motor? because i took a look at it before posting this thread, but everything seemed normal.
tsibole90, how did u fix yours?
Old 09-23-2007, 03:21 PM   #5 (permalink)
The Slowest of Slow
tsibole90's Avatar
My problem was that a screw holding the window to the regulator was too tight. I just loosened it a little bit and now it works perfectly.
Old 09-23-2007, 03:47 PM   #6 (permalink)
Toyota Technician
-=]KaiN[=-'s Avatar
you could have a cable binding or broken in your regulator. Make sure all the bolts are still in the regulator holding it correctly to the door, and glass. Check the front and rear window runs be sure they are in place correctly and the window is channeled correctly inbetween the rubber in the runs. If all looks normal chances are you just need a regulator.
Old 09-24-2007, 01:47 AM   #7 (permalink)
thanks for the replies. i will check it out once i have the time. i really have to do it before winter hits.
95 Avalon Power window problem krispykreme 1st Generation (1995-1999) 3 01-01-2007 10:45 PM
corolla window problem elgerahbkid Archived Corolla threads 0 09-20-2005 05:15 PM
power window problem Camon19z Camry & Solara Lounge 2 09-08-2005 10:01 AM
98 sienna power window problem badmonkey 1st Generation (1998-2003) 1 06-01-2005 09:53 PM
Power window problem on '95 Camry Conundrum 3rd & 4th Generation (1992–1996 & 1997–2001) 13 01-20-2003 12:36 AM
